POV-Ray : Newsgroups : povray.general : about DPI and resolution....???? help ! Server Time
1 Oct 2024 00:04:36 EDT (-0400)
  about DPI and resolution....???? help ! (Message 1 to 8 of 8)
Subject: about DPI and resolution....???? help !
Date: 16 Sep 2005 10:15:00
Message: <web.432ad3458a10e857703346660@news.povray.org>
Hi everyone
I need to create a picture with a specific size and resolution.
I am Linux user so I have a .ini file which contains info like the picture
size in pixels, e.g. :
Width=4000
Height=3200
But, I don't how to set the resolution. I've actually been asked to create a
picture with 300 DPI with a size of 213 x 161 mm
How do I do that ?
Cheers guys
Dav
Subject: Re: about DPI and resolution....???? help !
Date: 16 Sep 2005 10:19:12
Message: <432ad460$1@news.povray.org>
> Width=4000
> Height=3200
> How do I do that ?
Please read the messages in the thread started with
Date: Thu, 25 Aug 2005 11:32:03 EDT
Newsgroups: povray.newusers
Message-ID: <web.430de4731026f62e8ebe11d70@news.povray.org>
Subject: Specifying ppi
Xref: news.povray.org povray.newusers:12918
	Thorsten
Date: 16 Sep 2005 10:40:44
Message: <kurtzlepirate-75BE60.16404416092005@news.povray.org>
In article <web.432ad3458a10e857703346660@news.povray.org>,
 "Dav_shef" <nomail@nomail> wrote:
::Hi everyone
::I need to create a picture with a specific size and resolution.
::I am Linux user so I have a .ini file which contains info like the picture
::size in pixels, e.g. :
::Width=4000
::Height=3200
::But, I don't how to set the resolution. I've actually been asked to create a
::picture with 300 DPI with a size of 213 x 161 mm
::How do I do that ?
::Cheers guys
::Dav
simple : 1 inch = 25.4 mm
213 mm -> 213/25.4 at 300dpi -> 300*213/25.4 = 2515
161 mm -> 161/25.4 at 300dpi -> 300*161/25.4 = 1901
klp
Date: 16 Sep 2005 20:59:56
Message: <pdbNOSPAM-66C5AC.10595417092005@news.povray.org>
> Width=4000
> Height=3200
> How do I do that ?
DPI is "irrelevant", what you want to know about from a printing/quality
point of view is the number of pixels. DPI only comes into the game when
you consider printing an image at a paricular size. For example, your 4000
pixel wide image above, if printed 10 inchs wide will be 400DPI. The exact
same image printed at 20 inchs will be 200DPI.....a clear example of why
DPI as a measure isn't so useful.
The problem is that the printing industry is so steeped in the use of DPI
that they often don't understand what's really going on. So when they give
you a DPI value and an image size you simply multiply them to give the
right number of pixels. So for your example 300DPI at 213mm is
   300 * 213 / 25.4 pixels
or about 2500 pixels.
Now most image formats do have a DPI setting as part of the file information,
but again it is largely irrelevant except at the point of actually representing
the image on some media. It is the number of pixels that determines the
(potential) resolution and information content.
Paul Bourke
pdb(NOSPAM)swin.edu.au
Date: 16 Sep 2005 23:01:09
Message: <432b86f5$1@news.povray.org>
Dav_shef wrote:
> Hi everyone
> Width=4000
> Height=3200
> How do I do that ?
> Cheers guys
> Dav
You can't set the dpi within POV-Ray itself, but you can do it
'after-the-fact' with virtually any graphics editing program.  In
PaintShop Pro, for example, it's a setting in the resize dialog box.
Oops, that's Windows -- I now noticed you said Linux.  In the Gimp, it's
Image->Print Size.
All this does is change a data value in the header of the image file --
it does absolutely nothing to the image itself.
In your requested picture, 213 x 161 mm is 8.39 x 6.34 inches, so at 300
dpi it's 2516 x 1902 pixels.
      -=- Larry -=-
Date: 17 Sep 2005 18:50:05
Message: <432c9d9d@news.povray.org>
Larry Hudson wrote:
>> Dav
>      -=- Larry -=-
I should have also mentioned, as did several others in this thread, that
the dpi setting is in reality generally irrelevant.  Nevertheless, it
_is_ possible to adjust it with graphics editing software.  (Sometimes
it's rather obscure to find, but it's usually in there someplace.)
      -=- Larry -=-
Date: 17 Sep 2005 23:13:34
Message: <432cdb5e$1@news.povray.org>
As a member of the pre-press industry, I'm going to take extreme
umbridge at that! We do understand exactly what's going on. After all,
it's our livelyhood.
The problem comes from non-printing people not understanding what we
mean by DPI (and therefore by default, it is our fault for not
explaining ourselves fully).
These days the correct term is PPI (pixels per inch). It defines the
number of pixels of data we get in every inch in some output format.
We ask for an image to be at 'at least 300ppi' meaning that we need the
image to be at 300 *effective* pixels per inch (eppi). That means that
the internal file tag may say that the resolution is 300ppi but the data
is all still pixels.
We LIKE the image to have this internal tag as it makes it easier to
deal with the image once it comes into our page layout application. If
you provide an image tagged at 72ppi (or untagged), and we need to lay
it into the page at an eppi of 300dpi, we need pull out our calculators
and work out that 72/300 ... = 0.24 .. so we can't place the picture any
larger than 24%.
Later we come back to the layout to make the picture larger (for some
design reason) and notice that it's at 24% .. so, forgetting that it's
untagged, we figure we can make it 4 times as large without any
problems. But of course, we can't. That's why we want the image at the
correct ppi from the start.
Cheers!
Rick Measham
Date: 29 Sep 2005 02:08:17
Message: <433b84d1$1@news.povray.org>
Oh come on! It is just a hang over from the early days
of off-set printing. I remember getting black and white
photos printed through screens to get the resolution (in
dpi) that the off set printer could handle without smudging.
In that context it meant a lot. Today it's just dumb.
It should be irrelevant today. You can digitally resize
images to whatever dpi limits your printer has. As you say
your OUTPUT hardware has limitations defined in dpi, just
as it did 30 years ago. So yes, printers have to deal with
dpi, but there's no reason to ask for digital images defined by
both x-y dimensions and "ppi". To do so is either irrelevant
or redundant. The artist doesn't need to know how many square
inches you plan to cover with the pixels, only the number of
pixels.
If I have a 3000x2000 image it means nothing to give
it an internal tag of 72 dpi. If you resize it that internal
tag still means nothing.
The whole thing is so irritating because you need an
additional, and confusing piece of information. What
really upsets digital artists is that print oriented people
will ask for something by only specifying dpi. Completely
meaningless without the number of x and y inches. Then
you say, "yeah, but how large" and repeat the dpi! Augh!
> it makes it easier to deal with the image once it comes into our page
> layout application
Only because the software was designed for old school
printers who still think in terms of "dpi". Layout workers and
the software could completely disregard "dpi" until the finished
product is sent to the printer. In the old days it was difficult
or sometimes impossible to change an image to a different
resolution. In the analog days if you took a photo screened to
300 dpi and tried to rescreen it to a different odd dpi you would
I say it is an just an old school tradition that print media people
can't get over. It gives them a little convenience (even that
could be handled automatically by software anyway)
at the cost of confusing everyone else with an irrelevant
specification.
But I could be completely wrong. :)
I don't do much print layout :)
"Rick Measham" <rickm*at%isite.net.au> wrote in message
news:432cdb5e$1@news.povray.org...
>> give
> As a member of the pre-press industry, I'm going to take extreme umbridge
> at that! We do understand exactly what's going on. After all, it's our
> livelyhood.
> The problem comes from non-printing people not understanding what we mean
> by DPI (and therefore by default, it is our fault for not explaining
> ourselves fully).
> image to be at 300 *effective* pixels per inch (eppi). That means that the
> internal file tag may say that the resolution is 300ppi but the data is
> all still pixels.
> We LIKE the image to have this internal tag as it makes it easier to deal
> with the image once it comes into our page layout application. If you
> provide an image tagged at 72ppi (or untagged), and we need to lay it into
> the page at an eppi of 300dpi, we need pull out our calculators and work
> out that 72/300 ... = 0.24 .. so we can't place the picture any larger
> than 24%.
> untagged, we figure we can make it 4 times as large without any problems.
> But of course, we can't. That's why we want the image at the correct ppi
> from the start.
> Cheers!
> Rick Measham
