POV-Ray : Newsgroups : povray.general : Grayscale Server Time
10 Aug 2025 09:34:48 EDT (-0400)
  Grayscale (Message 1 to 3 of 3)
Subject: Grayscale
Date: 23 Jun 2005 04:40:00
Message: <web.42ba75299907254ce5987fa60@news.povray.org>
Hi, I've generated a 16bit PNG RGB image from a .pov demo, but need this in
16bit grayscale format? PshopPro reads the image in as 8bit and only allows
editing in 8 bit, anyone know of any good shareware 16 bit editors or a way
to force POV-Ray to generate a grayscale rendering, not color?
Thanks!
Subject: Re: Grayscale
Date: 23 Jun 2005 06:30:01
Message: <d9e2sk$9qb$1@chho.imagico.de>
Not shareware but:
http://www.imagemagick.org/
http://cinepaint.sourceforge.net/
global_settings { hf_gray_16 on }
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 23 Jun 2005 12:17:22
Message: <AcMMZBA38quCFwjq@econym.demon.co.uk>
Although it doesn't directly address your problem, you might be
interested to note that it's possible to write third-party plugins that
operate on 16bit greyscale data that can be called from within PSP or
other image processing programs. The data is accessible and the plugin
can consider the format to be 16bit greyscale even if the calling
program thinks that its RGB. There are two simple plugins on my webpage
<http://www.econym.demon.co.uk/plugins/hf.htm> (I hope I spelled that
right) that deal with POV-compatible 16bit heightfield processing.
Mike Williams
Gentleman of Leisure
