POV-Ray : Newsgroups : povray.general : hardware requirements for multiple symultaneous randerings Server Time
16 Apr 2026 07:30:35 EDT (-0400)
  hardware requirements for multiple symultaneous randerings (Message 1 to 4 of 4)
Subject: hardware requirements for multiple symultaneous randerings
Date: 27 May 2005 10:40:01
Message: <web.42972f93e58362b2fbb089830@news.povray.org>
I want to achieve the following: I have a Flash application for doing online
some design/modeling, and I want to render the resulting scene with povray
(I'm taking the xml output from Flash, generate a pov file through a python
script and call megapov to render the scene), then I load the outputed
image in the browser.
My question is the following: which is the hardware recomandation for the
machine that is doing the randering, in order to ensure a good raport on
speed/quality ? Let's consider the example of 10 symultaneous randerings
for 800x600 px, top quality, fairly simple objects (mostly boxes) and
simple textures.
As it runs over the web and the user expects rapid results on his screen,
efficient timing is the most important factor to be achieved.
The hardware requirements are for a dedicated server, no clustering, no LAN
randering distribution.
Thanks
Subject: Re: hardware requirements for multiple symultaneous randerings
Date: 27 May 2005 11:36:20
Message: <42973e74$1@news.povray.org>
carpatic nous apporta ses lumieres en ce 2005-05-27 10:35:
> simple textures.
> Thanks
All the renreding is done by the CPU.
1: A fast CPU. Several CPUs (10 in your example) will enable to generate several
images in parallel.
2: A good amount of RAM to prevent going to the swap file.
What have NO effect: the video card
Date: 27 May 2005 15:10:19
Message: <4297709b$1@news.povray.org>
You can find some tips on the ideal hardware at the WikiPOV:
http://www.wikipov.org/ow.asp?SpeedGuide#hardware
HTH,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Date: 27 May 2005 19:48:52
Message: <4297b1e4$1@news.povray.org>
> simple textures.
> Thanks
Hmm, for a single dedicated server, a X1E Cray should fit the bill
nicely... 8^)
I built a "real time" raytraced imaging system about a year ago as a
proof of concept design, to do basically what you're describing.
Raytracing and rendering objects in the background and then making the
completed image available to the user. It worked ok with Dual 2.8 Xeon
processors running SuSE Linux, 4 GB RAM and a SCSI array. The problem is
in spawning several instances of povray to handle the rendering. Even
with a dual Xeon, it can eat up resources.
Consider having serveral users all requesting raytracings
simulteneously... not practical.
After playing with it a bit I decided to take a different approach.
I'm now using the MOSIX kernal patch and some fancy programming using
ERLANG to distribute my renderings between several servers. It smokes...
