POV-Ray : Newsgroups : povray.general : how to make an object transparent? Server Time
10 Sep 2025 11:39:47 EDT (-0400)
  how to make an object transparent? (Message 1 to 5 of 5)
Subject: how to make an object transparent?
Date: 15 Apr 2005 04:50:00
Message: <web.425f7f274f3691ec2d341c80@news.povray.org>
Hi!
I have written an object consisting of some sphere, planes and difference
and intersection, all with their own textures and/or pigments.
when using the object what could i add to make it appearing transparent?
(50% transparent for example)
pigment with rgbf or rgbt doesn't work here.
Additional: Is there a special command to show movement?
Greetings
Dieter
Subject: Re: how to make an object transparent?
Date: 15 Apr 2005 07:46:11
Message: <425fa983@news.povray.org>
That's (almost) the best you can do. You might find that using merge{}
instead of union{} to hold the object together will make it look better (no
internal surfaces will be visible), and you can use an internal_texture to
make it so you only see the object on the way in and not the way out (so you
don't see the backside), but if there are two surfaces in front of each
other then you'll still be able to see them both. However...
Mega-POV has a motion_blur feature that can be used for this. In addition,
motion blur can be used to make an entire object 50% transparent. Set the
object to do its motion for the first 50% of the clock time, and for the
rest, use an #if to scale the object really small and put it somewhere
off-screen. Then it will only be 50% visible, and as streaked as you want
it.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 15 Apr 2005 16:09:00
Message: <42601f5c$1@news.povray.org>
D. H. Berlin nous apporta ses lumieres en ce 2005-04-15 04:45:
> Hi!
> Greetings
> Dieter
You may need to add the filter or transmit components to each object individualy. I
don't think that
adding a texture{transmit 0.5} to the whole union will work in your case, but you may
try.
Date: 16 Apr 2005 05:10:01
Message: <web.4260d5f58cdced01adccfadd0@news.povray.org>
You may also need to define or increase the max_trace_level in
global_settings (see documentation 2.4.2.1 on why this may be needed, and
3.3.3 for syntax)
Etienne
Date: 18 Apr 2005 23:20:01
Message: <web.426478328cdced01c505bd620@news.povray.org>
> 3.3.3 for syntax)
> Etienne
I haven't done this up to now, but i'm sure i have to do it. Because using
transmit/filter on all seperate parts of the intersecion/differnece
resulted in simply black.
Or i have to use merge somehow on the objec, what i haven'T done so far,
because it wouldn't be optimal for scene logical reason.
Thanks all for the help.
Greetings DH
