POV-Ray : Newsgroups : povray.general : Workarounds for persistent variables. Server Time
13 Aug 2025 11:06:56 EDT (-0400)
  Workarounds for persistent variables. (Message 1 to 3 of 3)
Subject: Workarounds for persistent variables.
Date: 9 Mar 2005 12:15:01
Message: <web.422f2e68d98bb7e240d56c170@news.povray.org>
What's the smartest SDL coding option to replace what might have been done
with persistent variables?
1) Recalculating the events of  frames 1 to n-1 for every nth frame;
2) writing to disk each time there's an event that needs to be remembered.
Q: What happens however upon each re-opening of a file-- will the old
material that's in the file be discarded, or are newly written records
appended at the end?
Subject: Re: Workarounds for persistent variables.
Date: 9 Mar 2005 15:49:13
Message: <EB0yfAADF2LCFwrV@econym.demon.co.uk>
Which one is smartest depends on how long it takes to calculate the
changes from one frame to the next.
If the calculations are quick, recalculate each time. Once you know how
to calculate one frame it's easier to write a simple loop round the
calculation than to add file handling.
If the calculations are slow, write to disk.
The #fopen command has a "write" option which zaps any existing data,
and an "append" option which appends the data to the end.
Mike Williams
Gentleman of Leisure
Date: 14 Mar 2005 21:52:29
Message: <42364ded@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:EB0### [at] econymdemoncouk...
Wow.  did not know that.
