POV-Ray : Newsgroups : povray.general : cos & sin functions Server Time
10 Sep 2025 17:21:01 EDT (-0400)
  cos & sin functions (Message 1 to 7 of 7)
Subject: cos & sin functions
Date: 19 Feb 2005 15:55:03
Message: <web.4217a68c1eb30463d977fb9c0@news.povray.org>
i'm working on a trebuchet, that i should have animated. The problem is,
that i gotta have a piece rotating around a centerpoint in a circle. I'm
going to use cos and sin functions to get the x and y coordinates like
this:
cos(A)*r=x
sin(A)*r=y
A=angle r=radius
The problem is, that when i use it, either the POV-Ray, or my calculator are
calculating wrong - most likely POV-Ray. my .pov code looks like this:
#include "woods.inc"
declare beam = box{<0,0,0><1,1,1>
texture{T_Wood20}
#declare ANGLE = 1; /*change this to 1,2,3 etc.*/
object{beam scale<1.9,35.56,1.27> translate<0,43,2.54> translate
x*cos(ANGLE)*-22.86 translate y*sin(ANGLE)*-22.86}
For me, it just looks like the beam is jumping around, rather than following
a circular pattern, which it should do.
Hope you can help me.
-Tjeiken
Subject: Re: cos & sin functions
Date: 19 Feb 2005 16:03:42
Message: <4217a9ae$1@news.povray.org>
take in count that pov rotates objects en degrees, but count sin and cos
functions in radians, then
instead
object {XX rotate x*cos(30),
use a conversion inside de cos function
object {XX rotate x*cos(radians(30))}
B Gimeno
estoeslarealidad
http://usuarios.lycos.es/game2413
light_source {0,1}#local C=cylinder{x*-2,x*2,.9}difference{box{-1,1}object{C
pigment {red 1}}object{C rotate y*90 pigment{green 1}}object{C rotate z*90
pigment{blue 1}} pigment{rgb 3}rotate 45 translate z*4}
news:web.4217a68c1eb30463d977fb9c0@news.povray.org...
> this:
> cos(A)*r=x
> sin(A)*r=y
> A=angle r=radius
are
> texture{T_Wood20}
following
> -Tjeiken
Date: 19 Feb 2005 16:10:35
Message: <4217ab4b@news.povray.org>
"Tjeiken" <nomail@nomail> wrote in message
> ... snip .... I'm going to use cos and sin functions to get the x and y
> coordinates ... snip ...
> are calculating wrong ... snip ...
> -Tjeiken
It's not just that sin() and cos() are in Radians is it?
If you're thinking in Degrees you need sind() and cosd().
Chris B.
Date: 19 Feb 2005 16:25:33
Message: <4217aecd$1@news.povray.org>
"B. Gimeno" <nos### [at] yacom> wrote in message
news:4217a9ae$1@news.povray.org...
> instead
> B Gimeno
Yes, the following rotates the wood beam in a complete circle:
camera {location -100*z up y right image_width/image_height*x look_at 50*y}
light_source {<100,100,-100>,1}
declare beam = box {
 <0,0,0><1,1,1>
texture {T_Wood20}
#declare ANGLE = radians(clock*360);
object {
 beam
 scale <1.9,35.56,1.27>
 translate <cos(ANGLE)*-22.86,43+sin(ANGLE)*-22.86,2.54>
Date: 19 Feb 2005 17:26:07
Message: <4217bcff@news.povray.org>
  Need? Not really. He *can* use them, but that's not the same as need. :)
  He can just use sin(radians(angle)) and cos(radians(angle)).
Date: 20 Feb 2005 01:39:44
Message: <kurtzlepirate-9E51FD.07394420022005@news.povray.org>
In article <web.4217a68c1eb30463d977fb9c0@news.povray.org>,
>>this:
>>cos(A)*r=x
>>sin(A)*r=y
>>A=angle r=radius
>>texture{T_Wood20}
>>-Tjeiken
yes use sind() and cosd() like this :
#macro sind(deg_angle) sin(radians(deg_angle)) #end
#macro cosd(deg_angle) cos(radians(deg_angle)) #end
#declare a = 30; // 30 degrees
#debug concat("\n sin(",str(a,0,0),") = ",str(sind(a),14,12))
#debug concat("\n cos(",str(a,0,0),") = ",str(cosd(a),14,12))
#debug "\n\n"
hope that help
Date: 21 Feb 2005 10:35:00
Message: <web.4219feb1518b8c2dd977fb9c0@news.povray.org>
Thx for all the help.. it works as it is supposed to now :)
