POV-Ray : Newsgroups : povray.general : problem with image transformation... Server Time
16 Apr 2026 16:39:38 EDT (-0400)
  problem with image transformation... (Message 1 to 4 of 4)
Subject: problem with image transformation...
Date: 8 Jan 2005 02:25:00
Message: <web.41df8992b1bdc25cda5747b10@news.povray.org>
hi!
i draw a cylinder with an image of me wrapped around it (multiple instances
of the image) like followed. but the image is drawn 2 times correctly an
the other times it i look cone-headed or completly misty (especially on the
top of the sylinder). what options could i use that there are multiple
images on the cylinder and each looks clearly?
thx for an answer
        location <-4,4,-4 >
 look_at  <0,0,0>
light_source {
  <-10, 18, -5>            // light's position (translated below)
  color White  // light's color
cylinder {
   <0,0,0>,
   <2,0,0>,
   2
 image_map {jpeg "C:ProgrammePOV-Ray for Windows v3.6pic.jpg" }
Subject: Re: problem with image transformation...
Date: 8 Jan 2005 04:28:24
Message: <41dfa7b8@news.povray.org>
Hash: SHA1
AJ wrote:
| hi!
instances
correctly an
(especially on the
	You want  to look at the map_type keyword. By default your image is
mapped to a plane which doesn't work too well in your case :) but you
can change that to a sphere, a cylinder or a torus (or u/v
coordinates). I don't remember what number is which though so you'll
have to rtfm for that part.
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFB36e3qIYJdJhyixIRAjD5AKCK5Z9ufRJUnGaA0hrZ/IyiT6oh/QCfSVlZ
wrJnEWKesFcAU9sa2pPLBdI=
=7zCn
-----END PGP SIGNATURE-----
Date: 8 Jan 2005 06:12:09
Message: <+sXskAA9$73BFwTq@econym.demon.co.uk>
>Hash: SHA1
>AJ wrote:
>| hi!
>instances
>correctly an
>(especially on the
But if you use map_type 2, you only ever get one copy of the image
wrapped round the cylinder. Using scaling or frequency doesn't let you
get multiple copies of the image wrapped round the cylinder.
I suspect that it might be possible to use three pigment functions, one
for each colour channel, perform scaled cylindrical polar
transformations on them and combine the three results back together.
There was a thread somewhere a while ago about how to combine pigment
function channels which I didn't take note of.
A uv_mapped Surface of Revolution does support multiple image_mapped
images, so you can do this:
        location <-4,4,-4 >
 look_at  <0,0,0>
light_source {
  <-10, 18, -5>
  color White
sor {4,
    <2, -2>
    <2, -1>
    <2, 1>
    <2, 2>
    uv_mapping
      scale <0.1,1,1>
  rotate z*90
Or, if you don't want the end caps painted like that:
        location <-4,4,-4 >
 look_at  <0,0,0>
light_source {
  <-10, 18, -5>
  color White
intersection {
 box {<-1,-2,-2><1,2,2> pigment {rgb 1}}
 sor {4,
    <2, -2>
    <2, -1.1>
    <2, 1.1>
    <2, 2>
    uv_mapping
      scale <0.1,1,1>
  rotate z*90
Mike Williams
Gentleman of Leisure
Date: 8 Jan 2005 10:02:14
Message: <41dff5f6$1@news.povray.org>
Hash: SHA1
	You're right, if you want to have several copies of the image, you
need to use planar mapping, scale your image by 1/number on the y
axis and apply a cylindrical warp with an orientation of x.
	Untested sample code:
~        location <-4,4,-4 >
~ look_at  <0,0,0>
light_source {
~  <-10, 18, -5>            // light's position (translated below)
~  color White  // light's color
cylinder {
~   <0,0,0>,
~   <2,0,0>,
~   2
~   pigment {
~     image_map {jpeg "C:\ProgrammePOV-Ray for Windows v3.6\pic.jpg" }
~     scale <1, 1/7, 1>
~     warp { cylindrical orientation y }
		Jerome
iD8DBQFB3/X2qIYJdJhyixIRAnd5AJ0UZs0z1CDQO6L58DR5jsVd7OJ7GQCfW7uW
UeeX/88s9Cn8DyJs+K3vHDw=
=k4U4
