POV-Ray : Newsgroups : povray.general : Semi Scaled cone Server Time
16 Aug 2025 01:16:32 EDT (-0400)
  Semi Scaled cone (Message 1 to 5 of 5)
Subject: Semi Scaled cone
Date: 13 Dec 2004 04:15:00
Message: <web.41bd5cb0e6a71ad6362130900@news.povray.org>
Hello. As I do pictures I keep having this same problem. I need to make a
cone that has a scale applied to only one end. I'll give an example. I want
to make a Forearm. One end is at the elbow and the other at the wrist. Now
the elbow end can have a normal diameter, but the wrist end will need to be
a little flattened. I use window version. Any advice?
Subject: Re: Semi Scaled cone
Date: 13 Dec 2004 05:54:31
Message: <41bd74e7$1@news.povray.org>
Barehunter nous apporta ses lumieres ainsi en ce 2004-12-13 04:11... :
Try with a blob made out of many spheres. Those at elbow level been
unscaled, changing progressively to the proportion you want at the wrist
level. Both end will be rounded, but you can flaten those with: 1- a
negative strenght component at each end, or 2- intersecting the blob
with a box of apopriate size.
Date: 13 Dec 2004 08:30:14
Message: <JXo6pDAclZvBFw3p@econym.demon.co.uk>
You can make something a bit like that from a cubic.
Let's consider the general case where you want to have elliptical ends
given by the 2d equations
        A2x2  +  B2y2  -  1  =  0
        C2x2  +  D2y2  -  1  =  0
then that can be achieved by
 cubic {<0,0,C*C-A*A,A*A,0,0,0,0,0,0,0,D*D-B*B,B*B,0,0,0,0,0,0,-1>}
that expands to
       (C2-A2)zx2 +A2x2 +(D2-B2)zy2 + B2y2 -1 = 0
so when z=0 you get
                   A2x2             + B2y2 -1 = 0
and when z=1 the A2x2s and B2y2s cancel out leaving
        C2x2            +D2y2              -1 = 0
You then need to chop off the bits outside the range, and may want to
translate and stretch it, something like this. The "sturm" may be
required for some values of A,B,C,D.
intersection {
  box {<-2,-2,0><2,2,1>}
  cubic {
    sturm
  pigment {rgb 1}
  translate -0.5*z
  scale <1,1,10>
To have a circle at one end, set A and B to the same value.
This doesn't quite do exactly what you want because the sides aren't
perfectly straight like they would be in a true cone.
Mike Williams
Gentleman of Leisure
Date: 13 Dec 2004 09:32:50
Message: <41bda812@news.povray.org>
  If you want an exact cone with two ellipses as ends, use Supercone() in
shapes.inc.
Date: 17 Dec 2004 23:00:01
Message: <web.41c3aac4fcb36a407e4f500@news.povray.org>
> shapes.inc.
Supercone! I never messed with macros before but I'll definitely try this
one thanks.
