POV-Ray : Newsgroups : povray.general : 16-bit greyscale using rg values? Server Time
28 Dec 2025 18:26:58 EST (-0500)
  16-bit greyscale using rg values? (Message 1 to 3 of 3)
Subject: 16-bit greyscale using rg values?
Date: 1 Nov 2004 15:55:00
Message: <web.4186a25f26a673e570f077560@news.povray.org>
Hey,
The documentation mentions that POV-Ray can use the red and green color
values from a TGA image for the high and low bytes of a 16 bit value for a
heightfield. Has anyone made a patch to allow this to be done with other
formats, in my case, windows bitmaps?
This seems like it would be fairly trivial. Maybe I'll have to bust out a C
compiler ;)
I know PPM's can be used, but they're so space inefficient for my little
hard drive.
-brandon
Subject: Re: 16-bit greyscale using rg values?
Date: 2 Nov 2004 13:31:09
Message: <cjameshuff-6F2394.13310102112004@news.povray.org>
In article <web.4186a25f26a673e570f077560@news.povray.org>,
> hard drive.
You're space limited, and using windows BMPs?
How about putting them in PNG format? IIRC, 16 bit grayscale PNG will
work in height fields, and will be far smaller than red-green encoded 16
bit BMP. Or just use TGA...BMP doesn't have any advantages over it.
Anyway, you can use it with any file format. Simply make a pigment
function using the image in an image_map, then make a scalar function
using the .hf feature or combine the channels yourself. Then use that
function in an isosurface, HF mesh, or height field.
#declare PigFn = function {pigment {image_map {...}}};
#declare HeightFn = function {PigFn(x, y, z).hf};
You could even go further, and have 24 bit height values encoded in all
three channels. Or combine multiple images in useful ways, or mix them
with built-in patterns or mathematical functions.
http://tag.povray.org/
Date: 4 Nov 2004 18:00:01
Message: <web.418ab4551788a3d78e133600@news.povray.org>
> > hard drive.
> http://home.earthlink.net/~cjameshuff/
I'll do what you said and use 24 bit! :D
Thank you for all the info!
-Brandon
