POV-Ray : Newsgroups : povray.general : output ff Server Time
11 Sep 2025 10:49:50 EDT (-0400)
  output ff (Message 1 to 5 of 5)
Subject: output ff
Date: 15 Oct 2004 22:45:00
Message: <web.41708aa9e8322a0e881c75c90@news.povray.org>
how do you set output fileformats to png and tga so it out puts tranparancy
as well?
Subject: Re: output ff
Date: 15 Oct 2004 22:57:43
Message: <41708e27$1@news.povray.org>
tranparancy
> as well?
Add the +UA switch.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 15 Oct 2004 23:30:00
Message: <web.417094915df0f148881c75c90@news.povray.org>
> tranparancy
> > as well?
> Add the +UA switch.
>  - Slime
that sets it to render with trans but it still saves it as a bmp destroying
the trans data
Date: 16 Oct 2004 01:47:47
Message: <Wsem0CA2XLcBFwO0@econym.demon.co.uk>
>> tranparancy
>> > as well?
>> Add the +UA switch.
>>  - Slime
>the trans data
That's because the BMP format doesn't support transparency.
Use PNG by adding +FN or TARGA by adding +FC or +FT.
If you want to change the default file format, so that you don't have to
remember to use the switches each time, then you can edit your master
POVRAY.INI file (in the Tools menu) to add the switches you want to be
active by default.
Mike Williams
Gentleman of Leisure
Date: 16 Oct 2004 01:51:39
Message: <4170b6eb$1@news.povray.org>
destroying
> the trans data
Oh, sorry, since you said "as well" I figured you already knew how to set
the file format.
As Mike Williams said, use +FN or +FT.
 - Slime
