POV-Ray : Newsgroups : povray.general : Anyone familiar with SMPov? Server Time
1 Mar 2026 17:25:34 EST (-0500)
  Anyone familiar with SMPov? (Message 1 to 3 of 3)
Subject: Anyone familiar with SMPov?
Date: 24 Sep 2004 10:20:00
Message: <web.41542c76fc1f41d9a3fcf12a0@news.povray.org>
I'm trying to use SMPov to render a scene across multiple CPUs, and I am
having some difficulties with it. I can kind of see where the hang-up is by
turning up the communication logging in Times.log, but I don't know how to
fix the problem. The Times.log file is full of the following message:
## 09:51:00: Sleeping till:
Z:\COM\JOB\BLOCK_09242004_095011_87176_1T_GX_9889_1.no
And here are the contents of my Z:\COM\JOB directory:
block_09242004_095011_87176.info
block_09242004_095011_87176.pnd.txt
block_09242004_095011_87176_PP.bat
block_09242004_095011_87176_10T_GX_9642_1.ask
block_09242004_095011_87176_11T_GX_9889_1.ask
BLOCK_09242004_095011_87176_1T_GX_4380_1.yes
block_09242004_095011_87176_2T_GX_1128_1.yes
block_09242004_095011_87176_3T_GX_8757_1.yes
block_09242004_095011_87176_4T_GX_3047_1.yes
block_09242004_095011_87176_5T_GX_5826_1.yes
block_09242004_095011_87176_6T_GX_4517_1.yes
block_09242004_095011_87176_7T_GXXXX_2594_1.yes
block_09242004_095011_87176_8T_GX_3601_1.yes
block_09242004_095011_87176_9T_GX_3573_1.yes
block_09242004_095011_87176_1T_ 2588641 792.job
block_09242004_095011_87176_2T_ 6276931 554.job
block_09242004_095011_87176_3T_ 9629511 785.job
block_09242004_095011_87176_4T_ 9704631 727.job
block_09242004_095011_87176_5T_ 7697631 59.job
block_09242004_095011_87176_6T_ 5308321 13.job
block_09242004_095011_87176_7T_ 6703781 353.job
block_09242004_095011_87176_8T_ 6599621 388.job
block_09242004_095011_87176_9T_ 9143931 128.job
block_09242004_095011_87176_10T.bat
block_09242004_095011_87176_11T.bat
block_09242004_095011_87176_12T.bat
block_09242004_095011_87176_13T.bat
block_09242004_095011_87176_14T.bat
block_09242004_095011_87176_15T.bat
block_09242004_095011_87176_16T.bat
Does this mean that computer GX_9889 is not responding? Is that the problem?
It looks like SMPov is looking for the wrong filename. GX_9889 seems to be
requesting tile 11, but SMPov seems to be looking for communicaitons on
tile 1. I tried creating a file called
BLOCK_09242004_095011_87176_1T_GX_9889_1.no, and then things seem to
progress ok, but this seems like a silly thing to need to do. Is this a
known bug on SMPov? I am using SMPov v4.2, and POVRay v3.6. All renderings
are running on 3.2GHz P4 computers. OS varies: mostly XP Pro, a few Win2K,
one NT4, and a couple Win98.
Subject: Maybe .... :-)
Date: 24 Sep 2004 13:55:04
Message: <41545f78@news.povray.org>
Hi Daniel,
1. Interactive preferred
Generally to get help with SMPOV its advised that get in interactive contact
with me (MSN-Messenger or SKYPE).
2. Network description
Also you would best sent me an description of how the Network environment
ist (no and names of machines).
3. Contents of COM-Folder AND times.log with "log communication"
Then additionaally to the contents of the COM-Folder, more important is that
you render using the new
"log communication" Switch at the lower right side of SMPOV. Then sent me
the times.log-file.
With these informations the mistake can be found.
--Theo Gottwald
"dan B hentschel" <dan### [at] alumritedu> schrieb im Newsbeitrag
news:web.41542c76fc1f41d9a3fcf12a0@news.povray.org...
> by
> problem?
Subject: That the problem!
Date: 27 Sep 2004 11:21:09
Message: <41582fe5@news.povray.org>
I think we found a problem.
To prevent others from falling into this trap, I'll post here what it is
about.
Daniel wrote me:
>because I am starting RenderAgent.exe from the same network shared folder
>on all the clients
So please don't start a RenderAgent multiple times.
When the RA communicates with SMPOV/Main he uses a UNIQUE NAME which is been
stored an his "own" R-Private.ini file.
If you start this RA (from this Location = with this R-Private.ini-File)
then the RA has NO UNIQUE NAME.
And of course things do not work then. Is just ike you have many persons in
a bussiness ALL WITH THE SAME NAME.
You can start multiple RA's even on a singel machine, however, each of them
need to be from within his own folder and have a unique NAME.
Thanks Daniel for reporting the mistake so I can post a warning, which is
NOT currently clearly visible in the SMPOV-Doku.
"Theo Gottwald ***" <yne### [at] it-beraterorg> schrieb im Newsbeitrag
news:41545f78@news.povray.org...
> Hi Daniel,
> contact with me (MSN-Messenger or SKYPE).
> that you render using the new
> the times.log-file.
> --Theo Gottwald
>> by
>> to
>> problem?
>> be
>> renderings
>> Win2K,
