POV-Ray : Newsgroups : povray.general : Way a win64 and not a linux 64 version of povray ? Server Time
19 Apr 2026 10:27:39 EDT (-0400)
  Way a win64 and not a linux 64 version of povray ? (Message 1 to 7 of 7)
Subject: Way a win64 and not a linux 64 version of povray ?
Date: 30 Jul 2004 06:05:00
Message: <web.410a1c5c83968b355787fbee0@news.povray.org>
I would like to know way you released a win64 version of povray and not one
for Linux, the win64 is in a very beta stage and not work with many
graphics cards, (My card for example.) and I never will use windows just
for  work with povray.
but the linux 64 is a great system, very fast, and a final release .
well.
It is I think.
Please, release one linux 64 bit version of povray for work with AMD Athlon
64.
tkz
Marcio Esper
Subject: Re: Way a win64 and not a linux 64 version of povray ?
Date: 30 Jul 2004 06:25:02
Message: <ced7jk$c05$1@chho.imagico.de>
> well.
> It is I think.
> 64.
The unix/linux source package you can download from
http://www.povray.org/download/ compiles on AMD64 systems without
problems (just like on all other 64bit systems we could test on).
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 30 Jul 2004 07:31:23
Message: <410a318b$1@news.povray.org>
Correct me if i'm wrong, but just because it compiles on the AMD64
doesn't make it a 64bit version, does it?
Arne
Christoph Hormann schrieb:
>> not one
>> well.
>> It is I think.
>> Athlon
>> 64.
> Christoph
Date: 30 Jul 2004 07:45:02
Message: <cedca5$jor$1@chho.imagico.de>
No, but the most common compiler on Linux (gcc) produces 64bit code by
default on 64bit systems (and i assume most other compilers do the
same).  Building the POV-Ray source package on a AMD64 without
explicitly specifying the -m32 option will result in a 64bit binary.
Date: 30 Jul 2004 18:05:18
Message: <410ac61e@news.povray.org>
  And what makes it a 64-bit version?
  If povray compiles as a 64-bit binary using gcc in linux if the target
platform is 64-bit, then what else is needed?
Date: 7 Aug 2004 23:30:01
Message: <web.41159e1a4e397d1d5787fbee0@news.povray.org>
I try to compiile but I get error in the last pacage, when I tru render a
glass the poovray return
Tracing Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
  Antialiasing.........Off
  Clock value:    0.000  (Animation off)
  0:00:00 Parsing
File: /tmp/kde-iceman/kpovmodelerrU3Khc.pov  Line: 4
File Context (5 lines):
sor {
   4,
   scale
Parse Error: Expected 'numeric expression', scale found instead
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  0 minutes  0 seconds (0 seconds)
many others objects work norrmal, but this onne not
That I can do to resolve this ?
thank you in advaance.
Date: 8 Aug 2004 01:00:02
Message: <cf4bvb$1jb$1@chho.imagico.de>
> sor {
>    4,
>    scale
What does this have to do with compiling POV-Ray?  This obviously is an
error in your scene file.
BTW a spell checker would be strongly advisable for you.
