POV-Ray : Newsgroups : povray.general : how to hide interface between merged objects? Server Time
29 Dec 2025 13:04:01 EST (-0500)
  how to hide interface between merged objects? (Message 1 to 3 of 3)
Subject: how to hide interface between merged objects?
Date: 11 Apr 2004 09:24:49
Message: <web.407900fd27068172668ad840@news.povray.org>
I want to render only the exterior surface after merging two
semi-transparent objects.  Although the original sruface of each object
inside the CSG is not traced, pov-ray traces a new surface that intersects
the two objects.  Is there a way to hide this interface?
Tom
Subject: Re: how to hide interface between merged objects?
Date: 11 Apr 2004 10:03:16
Message: <40795024@news.povray.org>
tomlee wrote:
> Hi,
If you use "merge" this should not be the case, all inner surfaces get
removed. Can you post a minimal scene example that shows your problem?
Maybe you just have to increase max_tracelevel?
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 11 Apr 2004 10:03:41
Message: <4079503c@news.povray.org>
  It may help understanding what you mean if you post a short example
scene showing the effect you are talking about.
