POV-Ray : Newsgroups : povray.general : normals function Server Time
21 Feb 2026 22:07:39 EST (-0500)
  normals function (Message 1 to 10 of 14)
Subject: normals function
Date: 9 Jan 2004 21:00:02
Message: <web.3fff5c25782a2a3b6b19de950@news.povray.org>
Does povray have a built in function to calculate the norm of a triangle
from 3 vectors?
If not how whould I do this. I am not finding or understanding how to do
this.
Subject: Re: normals function
Date: 9 Jan 2004 21:13:53
Message: <3fff5fe1$1@news.povray.org>
> from 3 vectors?
> this.
It's actually very easy with POV-SDL when you know where the three corners
are: First, generate two vectors: Point 2 minus Point 1, that's Vector one,
and Point 3 minus Point 1, that's Vector 2. Now, use vcross(Vector1,
Vector2) and voila! You've got the surface normal.
With a little research using google and the internet, you'd find more
insightful information, but that's simply a basic approach.
vcross calculates the cross-product of two vectors, which is actually a
vector, which is perpendicular to both given vectors. And how did you get
these? Subtracting one point from another calculates a vector which is
actually the direction and distance from Point 1 to point 2 and 3 (when you
do Point3-Point1, its actually "going from Point1 to Point3" what you get,
hence subtracting the same point from the other two, but that doesn't really
matter for the cross-product).
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 9 Jan 2004 21:20:18
Message: <3fff6162@news.povray.org>
> from 3 vectors?
  vcross(Vertex2-Vertex1, Vertex3-Vertex1)
> this.
  Some high-school level math book is very useful for these things...
Date: 10 Jan 2004 13:50:01
Message: <web.400049479e7183876b19de950@news.povray.org>
>> from 3 vectors?
>> this.
It has been over 12 years for me and this I do not remember in my math.
Would have been nice. But thanks all for the help. I thought that vcross
was for this but my brain just was not putting every thing together.
Date: 10 Jan 2004 19:31:55
Message: <4000997b@news.povray.org>
  The cross-product of two vectors is defined as a vector which is
perpendicular to both and which length is the product of the lengths
of the two vectors multiplied by the sine of the angle between them.
The direction of this perpendicular vector is defined by the handedness
rule (first vector is thumb, second vector is index, result is middle
finger).
  One could wonder why the definition has to be this complicated, but
the idea is that calculating the cross-product of two vectors is very
easy to do with only multiplications and additions (ie you don't need
trigonometry at all).
  If the first vector is <ux, uy, uz> and the second is <vx, vy, vz>
then their cross-product is <uy*vz-uz*vy, uz*vx-ux*vz, ux*vy-uy*vx>.
(This result vector has the properties described above.)
  The most useful property of the cross-product is its perpendicularity,
which is used a lot in computer graphics for calculating normal vectors.
  (Another useful operator is the dot-product, but that's another story.)
Date: 11 Jan 2004 04:18:18
Message: <825200dr314odhi26lhm1qcah9tbjba24r@4ax.com>
Well tell it please, your cross-product story was iluminating.
Regards
Date: 11 Jan 2004 10:56:24
Message: <40017227@news.povray.org>
> Regards
  The result of the dot-product of two vectors is a scalar which is the
product of the lengths of the two vectors multiplied with the cosine of
  The good thing about the dot-product is that it's very easy to calculate
with multiplications and additions only. The dot-product of <ux, uy, uz>
and <vx, vy, vz> is ux*vx+uy*vy+uz*vz.
  When the two vectors are unit vectors, their dot-product is simply the
cosine of the angle between them (because the product of their lengths
is 1).
  This property is very useful for many things. For example the lighting
at a certain point in a surface is proportional to the cosine of the angle
between the normal vector and the vector which points towards the light
source. This is very fast to calculate with the dot-product (when the
two vectors have been normalized).
Date: 11 Jan 2004 12:00:07
Message: <cjameshuff-A7A76E.12002011012004@netplex.aussie.org>
In article <40017227@news.povray.org>, Warp <war### [at] tagpovrayorg>
And it's worth mentioning what happens when you compute the dot product
of a vector with one of the natural basis vectors (x, y, and z). Given
the vector V = < a, b, c>:
V dot x = a*1 + b*0 + c*0 = a
V dot y = a*0 + b*1 + c*0 = b
V dot z = a*0 + b*0 + c*1 = c
So writing vdot(A, x) is the same as writing A.x, which happens to be
the notation used in mathematics for dot products...though it actually
comes from C, where it is used to refer to a member of a struct.
Anyway, that means acos(A.x) means the same thing as acos(vdot(A, x)):
the angle in radians between the vector and the x axis.
http://tag.povray.org/
Date: 11 Jan 2004 14:29:43
Message: <q09300h9mla6kqn837qifvk46tjoen3j7o@4ax.com>
On 11 Jan 2004 10:56:24 -0500, Warp <war### [at] tagpovrayorg> wrote:
>  The result of the dot-product of two vectors is a scalar which is...
Thanks Warp and to you Christopher
Regards
Date: 11 Jan 2004 20:31:17
Message: <4001f8e5@news.povray.org>
  Only if A is a unit vector. (If it isn't, you need to normalize
it first.)
