POV-Ray : Newsgroups : povray.general : Color function question Server Time
23 Nov 2025 19:32:59 EST (-0500)
  Color function question (Message 1 to 5 of 5)
Subject: Color function question
Date: 5 Sep 2003 19:40:01
Message: <web.3f591e9a75ce2c7d5d6ae59e0@news.povray.org>
Excuse me if this has been answered.
If I declare a function from an image map like so:
#declare Image = pigment{ image_map{ "goth.bmp" once} }
#declare f_Image = function{ pigment{Image} }
then use the function as a pigment:
plane{
        -z, 0
        pigment{ function{f_Image(x,y,z).gray} }
....it works but everywhere outside <0,0,0> to <1,1,0> on the plane is set to
a medium shade of gray. Am I doing something wrong?
Janger
Subject: Re: Color function question
Date: 5 Sep 2003 19:50:31
Message: <3f592147$1@news.povray.org>
to
That sounds like the correct behavior. Perhaps you didn't want to include
the "once" keyword?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 5 Sep 2003 22:59:10
Message: <3f594d7e@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message
news:3f592147$1@news.povray.org...
set
> to
> the "once" keyword?
If the idea was to place a single image onto the plane and leave the rest
transparent then I don't believe there's any way to do that in this way.
You'd need to clip away all areas surrounding the image or tell it to be
transparent. Neither can be done within a function pigment, FAIK anyway.
Checking on that here, what you see is actually white not gray. Use an
ambient 1 for the finish and you'll see. You can modify the pattern using
other functions or equations put in with the image function but that won't
remove parts, you still get a whole opaque plane. I tried combining a
transparent pigment and am not able to get just the image to show and leave
the rest empty.
Maybe someone else has more to say concerning this...?
Bob H.
Date: 6 Sep 2003 18:10:01
Message: <web.3f5a5a8110dfa9b1b246b3750@news.povray.org>
You are correct. Actually the camera was looking down slightly, so the white
looked more gray. For what I'm doing I could either apply the pigment to a
box, or use a 'picture frame' to mask out the white.
Thanks
Janger.
Date: 6 Sep 2003 18:47:52
Message: <3f5a6418$1@news.povray.org>
// What about something like this:
#declare Image = pigment{ image_map{ "goth.bmp" } }
#declare f_Image = function{ pigment{Image scale 2 translate <-1, -1, 0>} }
plane {
  -z, 0
  pigment{ boxed
    pigment_map {
      [ 0 color rgbt 1 ]
      [ 1E-5 function{f_Image(x,y,z).gray} ]
    translate <1, 1, 0>
    scale 0.5
plane { -z, -1 pigment { bozo } }
light_source { <-2, 1, -3>, rgb 1 }
camera { location -3*z look_at 0 }
//   Sputnik
