POV-Ray : Newsgroups : povray.general : underwater effect Server Time
16 Jan 2026 12:21:00 EST (-0500)
  underwater effect (Message 1 to 4 of 4)
Subject: underwater effect
Date: 28 Aug 2003 04:00:01
Message: <web.3f4db4935416ffcf93d602b70@news.povray.org>
how do i generate a effect that is something like light shining thru the
surface of the ocean and the light will reflect from the sea base.
Subject: Re: underwater effect
Date: 28 Aug 2003 05:49:45
Message: <3f4dd039@news.povray.org>
"trex" <rex### [at] yahoocom> wrote in message
news:web.3f4db4935416ffcf93d602b70@news.povray.org...
I'm going to guess you are talking about caustics; seen in swimming pools,
where the light has a network of concentrated illumination on the walls and
floor. Christoph Horman has a water tutorial showing such a thing.
http://www-public.tu-bs.de:8080/~y0013390/pov/water/water06.html
Bob H.
Date: 28 Aug 2003 07:46:59
Message: <3f4debb3@news.povray.org>
If what you want is rays of light through the water you can have a look
at the example scenes from the POV distrib called abyss.pov made by
master Tran.
JC
Date: 29 Aug 2003 18:43:44
Message: <Xns93E776957825raf256com@204.213.191.226>
rex### [at] yahoocom news:web.3f4db4935416ffcf93d602b70@news.povray.org
Make hole as an hollow object (i.e. box, or plane), give it some normal,
ior, and dispersion media. Then render all with photons and light source
above "sea". I have some sample images on ,my hdd but I must find them.
