POV-Ray : Newsgroups : povray.general : help in creating a kaleidescope effect Server Time
3 Mar 2026 02:22:41 EST (-0500)
  help in creating a kaleidescope effect (Message 1 to 4 of 4)
Subject: help in creating a kaleidescope effect
Date: 27 Jul 2003 08:30:01
Message: <web.3f23c4db18cccb436549b3060@news.povray.org>
Hello
Can anyone point me in the right direction for creating a kalediescope
effect in povray?
Any macros or incs or advice much appreciated.
Thanks
darrenf (zippy666)
Subject: Re: help in creating a kaleidescope effect
Date: 27 Jul 2003 15:22:26
Message: <3f242672@news.povray.org>
"darrenf" <dar### [at] ukonlinenet> wrote in message
news:web.3f23c4db18cccb436549b3060@news.povray.org...
> effect in povray?
Nothing I know of offhand but it can be done by using intersecting planes
having mirrored surfaces which form a multi-sided tube that the camera looks
through. Same as a real life kaleidoscope does. If there's a macro or other
script showing this it could probably be found in a search of the text or
binaries scene groups. Let me see if I can find one... No, not an example of
script anyway, although I should have a scene file I did long ago someplace
here.
Bob H.
You wouldn't need to see that, really. It's about as simple as:
intersection {
    plane {x,1 rotate 120*z} // sides
    plane {x,1 rotate 240*z}
    plane {x,1 rotate 360*z}
clipped_by {cylinder {0,7*z,2}} // remove excess tubing
texture {pigment {rgb 0} finish {reflection {1,1}}}
rotate 360*clock*z // make it animatable too?
// and something to kaleid
sphere {9*z,3 pigment {radial frequency 9} finish {ambient 1}}
Date: 28 Jul 2003 01:37:32
Message: <3f24b69c$1@news.povray.org>
// What about the following kaleidoscope, using a prism?
// An arbitrary number of mirrors are possible.
//   Sputnik
global_settings { max_trace_level 10 }
#declare N = 6; // number of mirrors
// kaleidoscope
prism { linear_spline linear_sweep 0, -6, (N+1)*2
  #declare I = 0;
  #while (I<=N)
    , <cos(I/N*2*pi), sin(I/N*2*pi)>*1.06
    #declare I = I+1;
    #end//while I
  #declare I = 0;
  #while (I<=N)
    #declare I = I+1;
    #end//while I
    pigment { color rgb 1 }
    finish { reflection 1 }
// wooden disc to look at
cylinder { 0, -y, 1
  pigment { wood scale .15 rotate 5*x translate 0.5 }
  finish { ambient 1 }
  translate -6*y
// camera, light
camera { location <0, 2, -0.25> look_at 0 }
light_source { <-4, 3, 2>*1000, rgb 1 }
// END
Date: 28 Jul 2003 06:35:01
Message: <web.3f24fbd37f50ca93ed623a40@news.povray.org>
Thanks for all the input - will try it out.
darrenf
>//   Sputnik
>// kaleidoscope
>  #declare I = 0;
>  #while (I<=N)
>    #declare I = I+1;
>    #end//while I
>  #declare I = 0;
>  #while (I<=N)
>    #declare I = I+1;
>    #end//while I
>  texture {
>cylinder { 0, -y, 1
>  translate -6*y
>// camera, light
>// END
