POV-Ray : Newsgroups : povray.general : surreal organic textures - need some help Server Time
22 Feb 2026 09:27:30 EST (-0500)
  surreal organic textures - need some help (Message 1 to 5 of 5)
Subject: surreal organic textures - need some help
Date: 14 Jul 2003 05:35:01
Message: <web.3f12788565af23e552c52af60@news.povray.org>
Hello
I am trying to make a surreal organic texture for some biowin
models/animations I am trying to create.
Mainly stuff like hr giger textures.
I have seen a bryce way of doing  this using a volumetric texture (see
http://www.petersharpe.com/Tutorial31.htm), and am not sure how to do this
in povray.
Also thinking of bio luminescence, and am not sure how to go about doing
this.
I have seen some of the AOI textures and this looks very cool, but as my
organic object is very complex, and I am trying to animate, it could take a
very long time (which i do not have).
Does anyone have any code/incs that can create wierd organic textures/hr
giger textures?
I have thought about image maps with  bozo texture on top, I might try this.
Thanks
darrenf
Subject: Re: surreal organic textures - need some help
Date: 14 Jul 2003 06:00:15
Message: <87v4hv015ms8rdrdu8c6ife3jou96bu4bh@4ax.com>
Why do you think AOI texture is slow? AOI realised as patch does not need many
calculations. It is basically just angle between two vectors.
ABX
Date: 17 Jul 2003 19:45:28
Message: <cjameshuff-A5FF39.18431217072003@netplex.aussie.org>
In article <web.3f12788565af23e552c52af60@news.povray.org>,
> in povray.
If you are trying for a glowing appearance, look at emitting media.
http://tag.povray.org/
Date: 2 Aug 2003 09:25:04
Message: <3f2bbbb0@news.povray.org>
Try this:
#declare texDark = texture {
    pigment { rgb 0.1 }
    normal { ripples 0.2 }
    finish { diffuse 1 ambient 0 }
#declare texMid = texture {
    pigment { granite
        color_map {
            [ 0 rgb <0.0, 0.7, 0.7> ]
            [ 1 rgb <0.0, 1.0, 0.0> ]
    normal { graite 0.3 }
    finish {
        reflection { 0.0, 0.3 metallic }
        ambient 0.3 diffuse 0.7
        phong 0.30  phong_size 100  metallic
#declare texLight = texture {
        crackle
        turbulence 0.8
        omega 0.75
        color_map {
            [ 0 rgb <1.00, 1.00, 0.95> ]
            [ 1 rgb <1.00, 0.85, 0.70> ]
    normal {
        crackle 0.23
        turbulence 0.8
        omega 0.75
    finish {
        reflection { 0.2, 0.7 }
        ambient 0.8 diffuse 0.2
        specular 0.7 roughness 0.001 metallic 0.4
#declare texSkin = texture {
    gradient x
    turbulence 0.2
    octaves 8
    omega 0.7
    texture_map {
        [ 0.100 texDark ]
        [ 0.150 texMid ]
        [ 0.200 texLight ]
        [ 0.300 texLight ]
        [ 0.350 texMid ]
        [ 0.400 texDark ]
        [ 0.675 texDark ]
        [ 0.725 texMid ]
        [ 0.775 texMid ]
        [ 0.825 texDark ]
The trick to "glowing" textures is the ambient part of the finish,
especially with radiosity.  If you load the sample scene "radiosity2.pov"
that came with POV-Ray and replace one of the object textures with texLight
or texSkin you will see what I mean.
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
this
> > in povray.
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 4 Aug 2003 12:04:07
Message: <cjameshuff-55250D.11022704082003@netplex.aussie.org>
In article <3f2bbbb0@news.povray.org>,
He mentioned volumetric textures. Ambient is only a surface effect, if
actual volumetric effects are desired, media is (almost) necessary.
