POV-Ray : Newsgroups : povray.general : density question Server Time
22 Mar 2026 10:31:01 EDT (-0400)
  density question (Message 1 to 9 of 9)
Subject: density question
Date: 13 Mar 2003 13:20:09
Message: <web.3e70ca66907276e0a3d219970@news.povray.org>
You guys are all so helpful.  This is my third question.  Thanks everyone.
#declare halo = object {
   // yadda yadda shapes yadda yadda lathes
   // something like conically shapped, but not really
    media {
       emission light_clr
       density {
          cylindrical scale 0.75
That's _almost_ what I want.  Actually I want for the media to be the
precise shape of the halo object in question... which is closer to conically
shaped that cylindrical.  Actualy, I misspoke.  The media is the precise
shape of the halo, the density falls off cylindrically though...
How can I make the emission falloff as I move away from the y-axis, in the
shape of the halo object instead of cylindrically?
Subject: Re: density question
Date: 13 Mar 2003 13:35:50
Message: <3e70cf86$1@news.povray.org>
    Have you tried "absorption"?
Version: 6.0.459 / Virus Database: 258 - Release Date: 2/25/03
Date: 13 Mar 2003 13:55:05
Message: <web.3e70d3797629df5ca3d219970@news.povray.org>
No, but from the docs that doesn't really do what I want.  I want for my
emission hase to be brighter toward the center of the cone and weaker near
the edges.  Absorbtion appears to just absorb a color... if you wanted it
to absorb more in the middle, you're back to using density {} again.
Date: 13 Mar 2003 14:04:45
Message: <Xns933DCCA362DE3seed7@povray.org>
in news:web.3e70ca66907276e0a3d219970@news.povray.org Jettero Heller
If your shape can be described with a function (think isosurface) you can
use that same function as a pattern for density.
Another option could be to render thin slices of your shape, blurr each
image (or maybe render with focal blurr) or postprocess them otherwise.
Then turn all the images into a single df3 density file (there is a
tga2df3 tool somewhere on the web). Use this as a pattern for your
density.
Ingo
p.s. It would be realy nice if somebody wrote a 3d-convolution tool for
df3 files. I tried it with Python but it isn't the most suitable tool for
it. Processing took lots of memory and ages.
Date: 13 Mar 2003 14:10:09
Message: <web.3e70d6f57629df5ca3d219970@news.povray.org>
It's actually occured to me that I can just put several of my lathes one
with inside the other at different scales.  Then adjust the media values for
each to make a gradient media effect.  That's a reasonable work around, but
I was hoping I could do this with density.
Date: 13 Mar 2003 14:20:02
Message: <3e70d9e2@news.povray.org>
"Jettero Heller" <pov### [at] voltar-confedorg> wrote in message
news:web.3e70d3797629df5ca3d219970@news.povray.org...
the
> the edges.
    Oh... I read it backwards. I thought you wanted it darker in the center.
Date: 13 Mar 2003 14:20:15
Message: <web.3e70d8af7629df5ca3d219970@news.povray.org>
It can't really.  It's a fairly complicated CSG.
but apparently you can use an object as a pattern?  In stead of applying a
media { density {}} to my halo object, could I make a big giant cylinder,
then use some kind of media {
   density {
      pattern { object { halo }}
or something like that?  The docs are a bit thin on that. :(
All they say about the object-patterns:
" The object pattern takes an object as input. It generates a, two item,
color list pattern. Wether a point is assigned to one item or the other
depends on whether it is inside the specified object or not.
Object's used in the object pattern cannot have a texture and must be solid"
That gives a good hint at least.  I can't wait to try some of this out when
I get home from work.
Date: 13 Mar 2003 15:34:26
Message: <Xns933DDBD87444Aseed7@povray.org>
in news:web.3e70d8af7629df5ca3d219970@news.povray.org Jettero Heller
Yes, but it wouldn't give you a gradient, just media or no media.
Ingo
Date: 13 Mar 2003 18:01:35
Message: <cjameshuff-8FFB15.18014613032003@netplex.aussie.org>
In article <web.3e70d6f57629df5ca3d219970@news.povray.org>,
You can do it with density, and it will render quite a bit faster than
the Matrioshka doll method you describe above. Who said you couldn't?
Off the top of my head, I can think of several ways:
As others suggested, use a function pattern. Hint: you can use splines
in functions. This is the simplest method. You might want to put the
spline control points in an array and write code to generate the lathe
and density spline from that, because there isn't one unified method for
specifying splines. (you can't use a spline as input for a lathe object)
Do something like your Matrioshka doll method with the object pattern.
The object pattern is solid, either one entry or the other, but you
could nest object patterns with different scales to get any number of
steps. This is more difficult to set up or change, and gives a finite
number of steps instead of a smooth gradient. I don't recommend this
method, too much work to set up, too inefficient and limited.
I'm assuming your lathe does not fold back on itself, in other words it
is like a cylinder with varying radius. If this is not the case, you
need to work on your definition a bit more, because what you described
can't be done.
http://tag.povray.org/
