![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
pov-ray ver: 3.5.icl.win32
Sys. op: Win xp
cpu: pentium 4, 256 MB
If i do (i.e.) y= cos(x) where 0 < x < 2*pi and i'm testing the following:
#if(y < 0)
//block1...
#else //block2...
the result when x= pi*3/2 is block1! And taking a look at its value, is
-0.00000 and is taken as negative number. By now i correct it simplyly
checking such y value: #macro correct(num)(num<0?:num=0?0:num:num) #end
Can someone confirm if this is a bug? Thanks
(sorry, but my english is very bad)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.3e319c0b7f992aa0e1b6456c0@news.povray.org> , "Jano"
No, the behavior is perfectly correct.
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Entre otras cosas, Jano tuvo a bien escribir:
> #if(y < 0)
> //block1...
> #else //block2...
What would you expect?
cos(0) = 1
cos(pi*1/2) = 0
cos(pi) = -1
cos(pi*3/2) = 0
Unfortunately, POV-Ray is not perfect and there are (as in most computer
programs) floatin point inaccuracies and rounding errors. That means the
result is not *exactly* 0, but slightly lower, and you see -0.000. This is
normal and expected behaviour, if you are testing against 0 you should in
turn test that abs(y) < tiny_number.
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>cos(0) = 1
>cos(pi*1/2) = 0
>cos(pi) = -1
>cos(pi*3/2) = 0
Thak you, i'll remember it next time :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3e31a57f@news.povray.org> , Jellby <jel### [at] M-yahoo com>
It isn't even a rounding error. PI can never be represented exactly in any
evaluation (assuming certain properties of PI are indeed true). So while
symbolically the result 0.0 is correct, numerically that cannot be reached.
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sure it can. pi = circumference/diameter
There, I just exactly represented Pi. :)
--Tim Cook
Version: 3.12
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> in any
...but sybolically, not numerically. The numeric representation
is left as an exercise for the student. 8)
Steve Martin, CPBE CBNT
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
any
Sure it cannot.
Could you please specify what exactly is "circumference" in your formula
(w/o just telling it's "diameter*pi")?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
