POV-Ray : Newsgroups : povray.general : Announce: 3DWin 4.7a, now with LDraw support Server Time
14 Jan 2026 16:33:55 EST (-0500)
  Announce: 3DWin 4.7a, now with LDraw support (Message 1 to 1 of 1)
Subject: Announce: 3DWin 4.7a, now with LDraw support
Date: 17 May 2001 11:38:51
Message: <u2s7gtkj60ba09g0nt22bv3mocqi5q6t49@4ax.com>
TB Software presents the new version of 3DWin, the 3D
file format converter. Beside several mesh processing
features it offers full uv and material support for
various 3d file formats.
3DWinOGL is a new member of the 3DWin product line.
It bases on the 3DWin engine and adds visual support
during the conversion process with help of OpenGL.
3DWin's strength is the high stability of processing
different file formats. "Quality not Quantity" is the
motto of the software development when commenting
number of supported file formats.
3DWin is available at
	http://www.stmuc.com/thbaier
What's new:
  * LDraw (Lego) import (www.ldraw.org)
  * Create and export new camera settings
Fixes:
Notes:
  * To use this Demo version the new Demo reg keys
    are required (Demo_Reg_Setup.exe)
  * If you are registered plase install also
    the Demo reg keys and then install the reg keys
    already sent to you.
3dto3d engine features:
  * running under Win95/98/ME/NT4/W2K/XP
    (linux under preperation)
  * easy installation
  * plugin architecture
  * updates via support web page.
  * clear and comfortable userinterface
  * full help support
  * fast and robust conversion routines
  * reliable handling of larges scenes
  * detailed statistics about conversion process
  * supports polygon meshes including normals and uv
    vectors
  * supports light and camera conversion
  * supports material and image map conversion
3DWin features:
  * fast and easy user interface
  * batch processing (registered version only)
  * drag&drop
Differences demo/registered version:
  * enabled support for material and image map
    conversion
  * enabled batch processing
  * some exports may miss every 5th vertex/edge/face
3DWinOGL features:
  * 3D Quad OpenGL views with mouse support
  * various OpenGL settings
  * UV view with material preview
  * multiple camera views
  * light view
  * multiple shading options for active and
    inactive objects (textured, colored,
    transparent and grey shading)
  * interactive manipulation of objects
    (mesh optimizing and transformations)
  * drag&drop
  * merge multiple scenes
  * exchange materials
  * selective export
Difference demo/registered version:
  * enabled 3d file export
Fileformats:
   Import:
   	Generic ASCII format (*.raw)
   	3dStudio (*.3ds, *.prj)
   	Lightwave (*.lwo, *.lws)
	Autodesk (*.dxf)
	WaveFront (*.obj)
	Protein Data Bank (*.pdb)
	Direct X (*.x)
	LightWave (*.lwo, *.lws)
	Quake MDL (*.mdl, *.md2)
	LDraw 	  (*.dat)
   Export:
   	3dStudio (*.3ds, *.asc)
   	Autodesk (*.dxf)
   	VRML 1.0/2.0 (*.wrl)
   	POV-Ray and Moray (*.inc, *.udo)
	WaveFront (*.obj)
	OpenGL (*.C)
	Renderman/BMRT	(*.rib)
	Lightflow (*.py)
	Direct X (*.x)
	Digistar  (*.vla)
