![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I originally ran into this problem running 3.5 RC6 on W2K, but 3.1g
exhibits the same problem. When I run the scene below, I get a parse
error, "no matching } in texture, # found instead." Here's a sample
file that causes the parse error:
#macro fooTexture()
pigment { Red }
#if (0)
pigment { Blue }
#else
pigment { Green }
#end //if(0)
#end//macro fooTexture()
#declare foo_texture = fooTexture()
Any #-whatever within the 2nd layer texture causes this error. Try
replacing the #if .. #else .. #end with #declare causeParseError =
1;
The strange thing is that if I put #if's in the Red layer, it parses
fine. OK, then you get "error: No objects in scene". :-)
Any idea what causes this problem? I know about the note in section
6.7.6, "Layered Textures", but that has to do with macros inside
layered textures. This is the other way around, layered textures
inside a macro. I don't see any syntax ambiguities.
Help?
-Scott
Download 'iso-8859-1' (4 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Scott Wasson wrote:
> texture {
> #if (0)
> pigment { Blue }
> #else
> pigment { Green }
> #end //if(0)
> replacing the #if .. #else .. #end with #declare causeParseError = 1;
If POV SDL is like C, might need to have #if flush with
left margin, instead of indenting it.
Tim Cook
Version: 3.12
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 18 Jun 2002 17:40:06 -0500, Timothy R. Cook wrote:
> If POV SDL is like C, might need to have #if flush with left margin,
Neither C nor POV-Script care about indentation, you must be thinking
about something else.
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: <chr### [at] tag povray org>
WWW: http://homepage.mac.com/chrishuff/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> 6.7.6, "Layered Textures", but that has to do with macros inside layered
> textures. This is the other way around, layered textures inside a
This is strange, I've never encountered it before...maybe it is just a
result of the layered texture definition being in a macro, so the parser
doesn't expect that construction.
It might work if you declared the layered texture as a local variable:
#macro()
#local localTex =
texture {}
texture {}
But I don't know how you would return the texture..."texture {localTex}"
would get picked up as a third layer, I think you would have to return
"localTex" and wrap the macro call in a texture {} block. Assuming this
trick actually helps...
Hopefully, a future version of POV-Ray will have an improved syntax for
defining layered textures...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks, but SDL ignores whitespace.
Has anyone tried my example and reproduced the problem?
-Scott
"Timothy R. Cook" <z99### [at] bellsouth net> wrote in message
news:3D0### [at] bellsouth net...
> Scott Wasson wrote:
> > texture {
> > #if (0)
> > pigment { Blue }
> > #else
> > pigment { Green }
> > #end //if(0)
> Tim Cook
> http://empyrean.scifi-fantasy.com
> mirror: http://personal.lig.bellsouth.net/lig/z/9/z993126
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 19 Jun 2002 09:59:42 -0400, "Scott Wasson" <swa### [at] townisp com>
Yes, I tried it but I still think it could be feature.
Consider such example
//START
#macro fooTexture()
texture { pigment { rgb y } }
#if (Condition)
#declare TMP=texture{ pigment{ rgb x } }
texture{ pigment { rgb z } }
//END
Tell me (without parsing) what should be last line of the macro - second leyer
of the first texture or second leyer of texture TMP ? Perhaps to avoid such
cases parser forbids any # which can leads to such situation. As Warp said You
in beta-test group SDL could be changed in this part and it is one of our
wishes for 4. Similiar limitation appear in case of such simple script:
//START
#if(#if(yes)yes#end)#end
//END
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:2151hu4iabm314mvp8sb0bi1i3inn3ghdq@4ax.com...
>1 //START
>2 #macro fooTexture()
>3 texture { pigment { rgb y } }
>4 #if (Condition)
>5 #declare TMP=texture{ pigment{ rgb x } }
>6 #end
>7 texture{ pigment { rgb z } }
>8 #end
>9 #declare foo_texture = fooTexture()
>10 //END
Conditional directives are nesting. Therefore the #end on line 6 closes the
#if on line 4, and the #end on line 8 closes the #macro on line 2. What am
I missing?
-Scott
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 19 Jun 2002 11:33:03 -0400, "Scott Wasson" <swa### [at] townisp com>
> #if on line 4
Yes, it closes #if and only #if, not SDL. Consider this example:
//START
#declare O=
#if(Condition)
sphere{ y 1 rotate x*30
#else
box{ -1 1 translate z
pigment{ rgb 1}
//END
Should it report missed "}" in sphere or box ? It is valid statement and no
doubts what is result of this script - there is no such thing like layered
object.
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Checked this out and found wrapping it in material {} makes it okay. So it
must be something in the program code that can't handle this properly
otherwise, as was already said before. The layered texture by itself just
sits there without definite boundaries for the parser, I guess. I've never
looked at the program code for it but that's what people always say and it
makes perfect sense.
bob h
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Depending on whether Condition is True or False, your example can be
rewritten as:
//START
#declare O=
// Condition = True
/* #else
pigment{ rgb 1}
//END
and for Condition=False:
//START
#declare O=
/* #if(Condition=False)
#else
//#end
pigment{ rgb 1}
//END
It's clear from these two examples that the first encounters a parsing error
in the sphere, and the second in the box. Your example behaves exactly the
same way, except the code that is "commented out" is done dynamically by
Condition. Again, the error will appear in either the sphere or the box
depending on whether Condition is True or False respectively.
-Scott
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
