POV-Ray : Newsgroups : povray.general : using a charact as #macro paramater? Server Time
8 Oct 2024 18:22:57 EDT (-0400)
  using a charact as #macro paramater? (Message 1 to 6 of 6)
Subject: using a charact as #macro paramater?
Date: 27 Aug 2001 11:19:42
Message: <slrn9okp6q.t5t.steve@zero-pps.localdomain>
Hi All
I've written a small macro to place chess pieces, I'm trying to call
the macro like this:
object{ place_piece(Black_Pawn, H, 2, 0) }
I've also tried
object{ place_piece(Black_Pawn, "H", 2, 0) }
But keep getting error messages, I've changed the
values in the switch evaluation to include the quote
marks etc but nothing seems to be working.
The macro doesn't seem to be able to take a character as a
paramater.
I'm getting errors like:
Parsing................................union{
      object{place_piece(Black_Pawn, "H", 2, 0)
object{Chess_Piece
       #switch (XFile <----ERROR
/home/sjlen/pov/blchess.pov:249: error: numeric expression expected but string
identifier found instead.
Any help gratefully receive.
  4:13pm  up 44 days, 18:17,  2 users,  load average: 1.14, 1.13, 1.04
Subject: Re: using a charact as #macro paramater?
Date: 27 Aug 2001 11:31:15
Message: <slrn9okpu5.m0.ron.parker@fwi.com>
The problem isn't the macro, it's the switch.  Switches don't work with
strings.  You can either use a chain of #if...#else #if...#else statements,
or you can switch to using numbers instead of letters.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 27 Aug 2001 12:35:46
Message: <slrn9okqqs.ti2.steve@zero-pps.localdomain>
Thanks Ron I'll change it to if's
  4:45pm  up 44 days, 18:50,  2 users,  load average: 1.00, 1.01, 1.00
Date: 27 Aug 2001 16:32:24
Message: <chrishuff-599533.15283527082001@netplex.aussie.org>
In article <slr### [at] fwicom>,
You might do the latter using the asc() function:
#switch(asc(Choice))
    #case(asc("A"))
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
Date: 27 Aug 2001 16:42:22
Message: <3b8ab0ae@news.povray.org>
Actually, you might be able to use  asc("H")  to get the number of a letter
(character code) and then use that as the switch parameter.  Could even use
small and capital letters, or other symbols, just open a character map to
see what's what.  "A" starts at 65 and integer count goes up from there to Z
then there's a few symbols between before "a" at number 97.  Caution:
there's several reserved small letters as you probably know.
Bob H.
Date: 27 Aug 2001 17:13:50
Message: <slrn9oldkl.uau.steve@zero-pps.localdomain>
>    #case(asc("A"))
Thanks Chriss, but I've already rewritten it to use all numbers, some how
55 isn't as intuitive as E5, particularly when looking at the chess board
in fron of me.
At the moment I'm just commenting each call to the macro // D4 just to help
me know where things are.
 10:05pm  up 45 days, 9 min,  2 users,  load average: 1.05, 1.04, 1.01
