![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What is wrong with below syntax ?
#declare P=.5;
#declare C=texture{pigment{color rgb 1}finish{ambient.5}}
#declare B=texture{pigment{color rgb 0}finish{ambient 0}}
#declare A=texture{average texture_map{[(1-P) C][P B]}}
texture{gradient y texture_map{[0 B][.5 A][1 C]}}
it causes error: ] expected but undeclared identifier 'A' found instead.
noticed in POV-Ray 3.1g and MegaPOV 0.7
ABX
#local A="000114120001121034130151142153134064180060195"#local B=0;#macro G()
#declare B=B+1;val(substr(A,B,1))#end#local S=seed(1);light_source{10,1}blob{
threshold.6#local U=z;#local Y=0;#while(Y<15)#local E=G()*.7+.1e-3;#local V=<
3.5-G(),G()-2.5,-1>;#local X=0;#while(X<1)sphere{<12*X+rand(S)-6,Y+rand(S)-5,
-1>1,1}sphere{U+X*(V-U)+rand(S)E,.3}#local X=X+.01;#end#local U=V;#local Y=Y+
1;#end texture{pigment{rgb 1}normal{agate}}}camera{location z*8look_at 0}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wlodzimierz ABX Skiba <abx### [at] abx art pl> wrote:
: #declare P=.5;
: #declare C=texture{pigment{color rgb 1}finish{ambient.5}}
: #declare B=texture{pigment{color rgb 0}finish{ambient 0}}
: #declare A=texture{average texture_map{[(1-P) C][P B]}}
: texture{gradient y texture_map{[0 B][.5 A][1 C]}}
: it causes error: ] expected but undeclared identifier 'A' found instead.
The problem is that two contiguous textures define a layered texture.
So you are defining a layered texture names 'A' and you are using 'A'
inside it.
Defining a texture alone is an error in itself anyways, so you can get rid
of both errors by defining the last line like:
#declare MyTexture = texture{gradient y texture_map{[0 B][.5 A][1 C]}}
#local D=array[6]{11117333955,7382340,3358,3900569407,970,4254934330}
#local I=0;#macro M()<mod(D[I],13)-6,mod(div(D[I],13),8)-3,10>#end
#while(I<6)cylinder{M()#local D[I]=div(D[I],104);M().1
pigment{rgb M()}}#local I=(D[I]>99?I:I+1);#end /*- Warp -*/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ambiguity. There's no way for POV to know that the last line isn't an
extra layer on the line before it, so as far as POV knows you're still
declaring A.
The workaround is to put something else in between.
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Not if it's the result of a macro, or if it's inside of an object definition.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This is one reason why semi-colons should be required in all #declares.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ron Parker wrote in message ...
> Ambiguity.
Thanks, that was reason.
I moved declarations outside object but I agree that it could be possible write
";" after any declaration to finish it
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> #declares.
And why the syntax for declaring a layered texture should be altered.
John
ICQ: 46085459
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
John VanSickle <van### [at] erols com> wrote:
: And why the syntax for declaring a layered texture should be altered.
It doesn't have to be if semicolons are used. A semicolon would end
the declaration, period.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
or rather. . .
"It doesn't have to be if semicolons are used. A semicolon would end
the declaration, semicolon."
:D
Batronyx ^"^
bat### [at] cadronhsa com
http://www.batronyx.com
Bhuddist monk to hotdog vendor:
"Make me one with everything."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
