POV-Ray : Newsgroups : povray.general : Loss of colour in shadow when using photons. Server Time
16 Aug 2025 21:06:03 EDT (-0400)
  Loss of colour in shadow when using photons. (Message 1 to 5 of 5)
Subject: Loss of colour in shadow when using photons.
Date: 12 Nov 2004 14:20:22
Message: <r73ap09eb4bs3f1n6rq7eac4bkekqiffht@4ax.com>
I do like a wee dram but I noticed that when I turned on photons the
whisky colour of the shadow went. I have posted an image in p.b.i
illustrating the problem. I've also appended an almost minimal scene
below. It was modelled in Moray for those of you that don't recognise
the coordinate system.
The leftmost glass has photons {pass_through} to simulate not using
photons.
Any help appreciated.
/////////////////////////////// Start Scene
 default {
    pigment { rgb <1,0,0> }
 global_settings {
  adc_bailout 0.003922
  ambient_light <1.0,1.0,1.0>
  assumed_gamma 2.2
  hf_gray_16 off
  irid_wavelength <0.247059,0.176471,0.137255>
  max_intersections 64
  max_trace_level 100
  number_of_waves 10
  noise_generator 2
  charset ascii
  photons {
    adc_bailout       0.01
    spacing           0.1
    gather            40, 200
    media             0, 1.0
    jitter            0.4
    max_trace_level   10
    autostop          0.5
    radius            0.0
    expand_thresholds 0.2, 35.0
background { color <0.000,0.000,0.000> }
camera {  //  Camera Camera01
  location  <     15.746,    -417.091,     207.490>
  sky       <    0.00000,     0.00000,     1.00000> // Use right
handed-system
  up        <        0.0,         0.0,         1.0> // Where Z is up
  right     <    1.62966,         0.0,         0.0> // Right Vector is
adjusted to compensate for spherical (Moray) vs. planar (POV-Ray)
aspect ratio
  angle         33.96215    // Vertical      21.226
  look_at   <      2.752,     -45.279,       2.064>
// *******  L I G H T S *******
light_source {   // Light001
  <0.0, 0.0, 0.0>
  color rgb <1.000, 1.000, 1.000>
  photons {
    reflection on
    refraction on
  translate  <327.54937, 375.867022, 207.551865>
// ********  MATERIALS  *******
#declare Checkered_1 =
   material  // Checkered_1
      texture
         pigment
            checker
               color rgb <0.752941, 0.752941, 0.752941>
               color rgb <0.878431, 0.878431, 0.878431>
         finish
            ambient 0.1
         scale  6.0
#declare SMcA_Glass =
   material  // SMcA_Glass
      texture
         pigment
            color rgbf <0.972549, 0.972549, 0.972549, 0.95>
         finish
            ambient 0.0
            diffuse 0.2
            phong 0.187033
            specular 0.050333
            roughness 0.7293
            reflection
               0.0294 , 0.07
               fresnel  off
               falloff  1.0
               exponent 1.0
               metallic 0.0
      interior
         ior 1.5
#declare SMcA_Whisky_Txt =
   material  // SMcA_Whisky_Txt
      texture
         pigment
            color rgbf <0.976471, 0.909804, 0.643137, 1.0>
         finish
            ambient 0.043133
            diffuse 0.0
            phong_size 18.54
            specular 0.223
            roughness 0.001
            conserve_energy
            reflection
               0.0686 , 0.245067
               fresnel  off
               falloff  1.0
               exponent 1.0
               metallic 0.0
      interior
         ior 1.2
         caustics 1.0
#declare White_1 =
   material  // White_1
      texture
         pigment
            color rgb <1.0, 1.0, 1.0>
         finish
            ambient 0.510767
// ********  REFERENCED OBJECTS  *******
#declare Whisky_Glass01 = difference {
  cone { // Cone004
    <0,0,0>, 0.75, <0,0,1>, 1.0
    photons {
      collect off
    scale <2.389483, 2.389483, 3.825727>
  cone { // Cone005
    photons {
      collect off
    scale <2.278917, 2.278917, 3.648704>
    translate  0.429522*z
  material {
    SMcA_Glass
  photons {
    collect off
#declare Whisky_Glass_Whisky01 = difference {
  cone { // Cone006
    <0,0,0>, 0.748, <0,0,1>, 0.998
    photons {
      collect off
  box { // Cube034
    <-1, -1, -1>, <1, 1, 1>
    photons {
      collect off
    scale <2.647984, 2.634917, 0.975282>
    translate  <-0.049435, 0.0, 3.559332>
  material {
    SMcA_Whisky_Txt
  photons {
    collect off
#declare Glass_and_Whisky01 = union { // Glass_and_Whisky01
  object { Whisky_Glass01 }
  object { Whisky_Glass_Whisky01 }
  photons {
    target 1.0
    reflection on
    refraction on
    collect off
  scale 8.520488
  translate  <55.755095, 32.143165, 0.024>
// ********  OBJECTS  *******
object { // Glass_and_Whisky02 -> Glass and Whisky01
  Glass_and_Whisky01
  photons {
    pass_through
  rotate <0.0, 0.0, 0.0>
  translate  <-62.452721, -2.465239, 0.0>
 box { // Page
  material {
    White_1
  scale <84.0, 118.800003, 0.02>
  translate  0.023133*z
plane { // Plane001
  z,0
  material {
    Checkered_1
  translate  -0.01*z
object { Glass_and_Whisky01 }
 /////////////////////////////// End Scene
Regards
Subject: Re: Loss of colour in shadow when using photons.
Date: 13 Nov 2004 12:38:02
Message: <4196467a$1@news.povray.org>
Stephen McAvoy nous apporta ses lumieres ainsi en ce 2004-11-12 14:20... :
>photons.
>Regards
>        Stephen
There is colour in the shadow, but only rhere the light does get
refracted. In the brightest parts it looks white due to cliping, it gets
to bright due to the focalization.
Date: 15 Nov 2004 05:44:46
Message: <352hp0p0apiju1ojag2tfii3jv3rk56bti@4ax.com>
>Alain
Thanks Alain, I see you found it in p.b.i
Regards
Date: 15 Nov 2004 05:53:23
Message: <41988aa3@news.povray.org>
Stephen McAvoy nous apporta ses lumieres ainsi en ce 2004-11-15 05:44... :
>>Alain
>Regards
>        Stephen
Here first. I did a test render with your code.
Date: 15 Nov 2004 06:12:22
Message: <bo3hp05km9isvdl42u2gj4olht2kdajs2u@4ax.com>
Thanks again for taking the trouble
Regards
