POV-Ray : Newsgroups : povray.general : report and question Server Time
4 Oct 2024 12:27:08 EDT (-0400)
  report and question (Message 1 to 9 of 9)
Subject: report and question
Date: 21 Jan 2004 03:55:12
Message: <pdb_NOSPAM-6A5159.19551121012004@news.povray.org>
You may be interested in this, written for a local computer graphics
and mathematics group
   http://astronomy.swin.edu.au/~pbourke/povray/representation/
I would also like any useful comments why figure 2 is so slow to
compute. I know there are some obvious small things like the 2pi
and perhaps changing the range but even so the compute time seemed
excessive.
Paul Bourke
pdb_NOSPAMswin.edu.au
Subject: Re: report and question
Date: 21 Jan 2004 03:56:53
Message: <pdb_NOSPAM-7370E5.19565221012004@news.povray.org>
> excessive.
ps: Artifacts occur with an accuracy of 0.01
Paul Bourke
Date: 21 Jan 2004 04:11:07
Message: <400e422b@news.povray.org>
I don't know the answer to your question per se (except that the
parametric object has always seemed extremely slow to me...),
but on a side note, I think the section 5, which contains the
iterative sierpinski tetrahedron, could perhaps create the
iterations in a loop.
  Like it is now it gives the impression that if you want to do
something like that you'll need to copy-paste that #declare as
many times as there are iterations, editing each one of them.
The POV-Ray SDL is more powerful than this.
  You can make an array (as large as the number of iterations),
each item containing one iteration, and you can fill this array
in a loop, each item using the previous one. Thus if you want
to change the number of iterations it's enough to simply change
one number (eg. a "#declare Iterations=6;" at the beginning).
Date: 21 Jan 2004 04:12:17
Message: <jegs00d5qt8o38682j9vajr5hpg7oln9l9@4ax.com>
On Wed, 21 Jan 2004 19:55:12 +1100, Paul Bourke <pdb### [at] swineduau>
> compute.
Did you tried 'precompute'?
ABX
Date: 21 Jan 2004 04:22:03
Message: <qps1e1-7a8.ln1@triton.imagico.de>
Good summary of the advantages of using POV-Ray for visualization tasks.
> excessive.
the parametric object is quite inefficient, in most cases it will be
much faster to use ingo's param.inc:
http://members.home.nl/seedseven/#param
see also:
http://www.econym.demon.co.uk/isotut/param.htm
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 21 Jan 2004 04:45:08
Message: <400e4a24@news.povray.org>
And I think Pov-Ray is even more powerful as even arrays are not needed
in this. The easiest way to do it is probably (I changed a few translates):
#declare Initial = union {
    triangle { < 1,  1,  1>,  <-1,  1, -1>,  < 1, -1, -1> }
    triangle { <-1,  1, -1>,  <-1, -1,  1>,  < 1, -1, -1> }
    triangle { < 1,  1,  1>,  < 1, -1, -1>,  <-1, -1,  1> }
    triangle { < 1,  1,  1>,  <-1, -1,  1>,  <-1,  1, -1> }
#declare iter=5;
#declare Old=Initial;
#while(iter)
     #declare New =
     	union{
         	object { Old }
         	object { Old translate <-2, 0, 2> }
         	object { Old translate <-2, 2, 0> }
         	object { Old translate < 0, 2, 2> }
         	translate <1,-1,-1>
         	scale 0.5
     #declare Old=New;
     #declare iter=iter-1;
object{New
     pigment {rgb 1}
Severi S.
Date: 21 Jan 2004 05:21:54
Message: <400e52c2$1@news.povray.org>
This is, of course, better :
> #while(iter)
>     #declare Old =
>         union{
>             object { Old }
>             translate <1,-1,-1>
>             scale 0.5
> #end
There is no need for "New at" all. "Old" is a bad choice for name now...
Severi
Date: 22 Jan 2004 02:35:34
Message: <pdb_NOSPAM-7E270A.18353322012004@news.povray.org>
> > #while(iter)
> >     #declare Old =
> >         union{
> >             object { Old }
> >             translate <1,-1,-1>
> >             scale 0.5
> > #end
That is significantly nicer, thanks, I've updated my example.
Paul Bourke
Date: 22 Jan 2004 02:39:22
Message: <pdb_NOSPAM-276BCC.18392222012004@news.povray.org>
> > compute.
Just now yes, without much difference. It thought that was more for
multiple instances.
I prcomputed the pi variables pi/2 and 2pi, narrowed the sphere,
it really is rather sad still.
Paul Bourke
