POV-Ray : Newsgroups : povray.general : macro parameters Server Time
16 Oct 2025 14:08:12 EDT (-0400)
  macro parameters (Message 1 to 4 of 4)
Subject: macro parameters
Date: 12 Feb 2006 03:32:15
Message: <kurtzlepirate-D923AB.09321512022006@news.povray.org>
hi,
i am trying to make a macro with one of parameters is "normal" like this
#macro foo(.., .., thisNormal, ..)
  normal { thisNormal }
ok, works fine... but in some cases i don't want normal.
how can i pass a "no-normal" or "empty-normal" parameters ?
any ideas ?
thanks.
Subject: Re: macro parameters
Date: 12 Feb 2006 08:24:22
Message: <43ef3706$1@news.povray.org>
"kurtz le pirate" <kur### [at] yahoofr> wrote in message
news:kurtzlepirate-D923AB.09321512022006@news.povray.org...
> hi,
> #end
> any ideas ?
> thanks.
Hi Kurtz,
I don't know how to do exactly what you ask. Just in case no-one else does
either, here's a work-around.
Forgive me if it's just dodging the question, or if it's describing
something that's already obvious to you.
Chris B.
camera {location <0,0,-4> look_at <0,0,0>}
light_source{<0,3,-10> rgb 1}
#macro foo ()
  cylinder {-1,1,0.5
      pigment {color rgb <1,1,1>}
      #ifdef (thisNormal) normal {thisNormal} #end
#declare thisNormal = normal {agate};
foo()
#undef thisNormal
object {foo() rotate -y*90}
#declare thisNormal = normal {marble 2 turbulence 0.5};
object {foo() rotate y*135}
Date: 12 Feb 2006 12:41:14
Message: <kurtzlepirate-50646F.18411412022006@news.povray.org>
In article <43ef3706$1@news.povray.org>,
> > hi,
> > #end
> > any ideas ?
> > thanks.
> Hi Kurtz,
> Regards,
> Chris B.
> #macro foo ()
>   cylinder {-1,1,0.5
>     texture {
> #end
> foo()
> #undef thisNormal
thanks chris. my english is not very good :))
but you help me. in fact, normal{} must be global's declared and not a
parameter for the macro and, with #ifdef and #undef i can make want i
want.
thanks too
Date: 15 Feb 2006 02:55:01
Message: <web.43f2ddf6d2798c27a671bd170@news.povray.org>
kurtz le pirate <kur### [at] yahoofr> wrote:
> hi,
> #end
> any ideas ?
> thanks.
If you prefer your own code (with thisNormal as a non-global declared
variable), you can use it like this, too:
#macro foo (thisNormal)
  cylinder {-1,1,0.5
      normal {thisNormal}
foo(normal {function {0}})
object {foo(normal {marble 2 turbulence 0.5}) rotate -y*90}
object {foo(normal {marble 2 turbulence 0.5}) rotate y*135}
// function {0} means "no normal"
