POV-Ray : Newsgroups : povray.general : Feature Request - Texture Override, Help Request Server Time
29 Sep 2024 11:21:59 EDT (-0400)
  Feature Request - Texture Override, Help Request (Message 1 to 10 of 20)
Subject: Feature Request - Texture Override, Help Request
Date: 15 Jan 2008 23:21:49
Message: <hp0ro31f9m1dr7spccdp4g3j0hj5fvhdh0@4ax.com>
Perhaps someone can help me figure out a way to do this...
I've built a brick road by unioning several hundred bricks to create a section of
road, and then
laying the sections end to end to form the complete road.  Each brick in a section has
a different
texture.  Now, I'm trying to add stripes to the road.  I can do it within the texture
statement used
for the bricks, but that creates stripes that are too uniform.  I'd like to have some
curvature and
disparities in the stripes, which I cannot figure out how to do without the
disparities being
obviously duplicated in each section.  Any ideas?
This is where I think a texture override would be very helpful.  The road could be
built as above,
unioning bricks to form sections and then unioning the sections to form the road.
Then an overall
texture could be applied that defines the stripes for the entire union.  This would be
helpful for
applying dirt textures too.
Any help would be appreciated.
Subject: Re: Feature Request - Texture Override, Help Request
Date: 16 Jan 2008 00:26:05
Message: <478d956d$1@news.povray.org>
Kyle napsal(a):
road, and then
has a different
texture statement used
some curvature and
disparities being
built as above,
Then an overall
be helpful for
union the bricks and apply a stripes texture (object rgb,Clear)
Date: 16 Jan 2008 08:19:23
Message: <b90so35gumm76bgjr66r6gl6qihvdm834e@4ax.com>
On Wed, 16 Jan 2008 06:25:54 +0100, Jan Dvorak <jan### [at] centrumcz> wrote:
I wish it were that simple.
I've put together a simple sample scene to better describe the issue.  As you'll see
in this scene, the bricks in each section are textured with individual pigment values.
 Because of this, any
texture applied to the o_Road object has no impact.  I can apply the stripes to the
bricks as they are created, but doing so causes obvious uniformity in the stripes.
I'd rather have the stripes not
be uniform and instead have some slight curvature to them as they are drawn down the
road.  Furthermore, I'd also like to be able to apply an overall "dirt" texture that
is more pronounced at the
edges of the road and not obviously uniform.
BTW, for anyone that is wondering, building the road in sections of bricks instead of
individual bricks conserves memory and parse/render time.
//+w700 +h500
//+w700 +h500 +a0.1 +j0.5 +am2
#include "functions.inc"
global_settings {
  assumed_gamma 1
  max_trace_level 15
light_source { vrotate (<0, 500, -500>, <0, -60, 0>), rgb 1 }
  location <-9, 5, 0> look_at <-5, 4.5, 15> angle 54
#declare l_Seed = seed(123);
#declare l_Gap = 0.125;
// basic brick
#declare o_Brick = box { <-4, -1, -2>, <4, 1, 2> scale 1/12 }
// brick pigment source
#declare p_Brick =
    gradient x
    color_map {
      [0 rgb <0.6055, 0.4423, 0.3066>]
      [1 rgb <0.7, 0.3, 0.2>]
// build a section of brick road
#declare o_Section =
  union {
    #declare Z = 0;
    #while (Z < 100)
      #declare X = 0;
      #while (X < 36)
        object {
          o_Brick
          pigment { eval_pigment(p_Brick, x*rand(l_Seed)) }
          translate <(X-18 #if(Z/2=int(Z/2)) +0.5 #end)*(8+l_Gap), 0, Z*(4+l_Gap)>/12
        #declare X = X + 1;
      #declare Z = Z + 1;
// put some sections together to build a road
#declare o_Road =
  union {
    #declare Z = 0;
    #while (Z < 10)
      object { o_Section translate z*Z*100*(4+l_Gap)/12}
      #declare Z = Z + 1;
object { o_Road }
Date: 16 Jan 2008 09:58:14
Message: <478e1b86$1@news.povray.org>
If you tend to have a planar road you could fake it with a small box /
plane right on top of the road. Apply a transparent colormap, use a
little turbulence  and there you go.
Arne
of individual bricks conserves memory and parse/render time.
  <snip>
Date: 16 Jan 2008 10:10:09
Message: <478e1e51@news.povray.org>
"Kyle" <hob### [at] gatenet> wrote in message
news:b90so35gumm76bgjr66r6gl6qihvdm834e@4ax.com...
> .. snip ...
> I can apply the stripes to the bricks as they are created, but doing so
> causes obvious uniformity in the stripes.  I'd rather have the stripes not
> drawn down the road.  Furthermore, I'd also like to be able to apply an
> overall "dirt" texture that is more pronounced at the
> ... snip ...
Hi Kyle,
I'd like a little more clarity about what you mean by 'stripes'. Do you mean
road markings such as the white lane markings and yellow no-parking lines
that you have on a lot of roads? If that's what you want I would suggest
adding a separate object that stands proud of the surface (like paint does)
and that tracks along the road rather than trying to do it just with
textures.
For dirt, you might want to try adding a mostly transparent object a very
small distance above the surface (a plane, a box or a prism object that
follows the course of the road) where the upper surface is just enough above
the brick surface to avoid coincident surfaces. You could use a 'spotted'
pigment to simulate dirt. If the bricks are not totally flat, some could
stick through this mostly transparent surface and would end up cleaner than
the rest.
Chris B.
Date: 16 Jan 2008 12:27:08
Message: <r6fso3525gj1fm5ular0uinna82enj64a0@4ax.com>
On Wed, 16 Jan 2008 15:58:12 +0100, Arne Kleinophorst <kle### [at] spamdebitelnet>
Yes, I've tried this method.  It looked kind of OK, but not to my liking.  In reality,
the paint on a brick road is usually not solid.  It is usually only painted on the top
of the bricks and is
usually quite worn off in many places too.  The worn look is easy enough, but the
paint crossing the gaps between the bricks is bothersome.  I've tried creating the
boxes for the lines, then
intersected them with the road and raised them up in the y direction a tad, but then I
had the texture of the road on the boxes due to the intersection.  Grr.  I may just
have to create a no-texture
copy of the road just to use for this purpose, even though it'll hog more memory.
Date: 16 Jan 2008 12:32:43
Message: <ijfso3dujkvp9073gnv7ndmnuqn2avisob@4ax.com>
Yes.
>textures.
I have done something like that, but was not satisfied with the result.  Take a look
at my reply to Arne a few minutes ago.  I may be able to use a no-texture version of
the road to form an
intersection where I want the lines, and then raise it up above the surface of the
road.  It'll require another copy of the road though...
>the rest.
Yes, that's part of the problem.  The bricks are not flat, but are randomly skewed to
look more realistic.  I may still be able to use this idea, or perhaps the
non-transparent road idea as outlined
above.
Thanks for the suggestions.
Date: 16 Jan 2008 14:15:00
Message: <web.478e576326ad74ae368884fc0@news.povray.org>
Try this:
//BEGIN
//+w700 +h500
global_settings {
  assumed_gamma 1
  max_trace_level 15
  location <0, 10, 0> look_at 0// angle 54
// basic brick
#declare p_Brick =
    gradient x
    color_map {
#declare p_Stripe =
    gradient x
    color_map {
      [0 rgbt <1,1,1,1,>]
      [1/2 rgbt <1,1,1,1,>]
      [1/2 rgbt <1,1,1,0,>]
      [1 rgbt <1,1,1,0,>]
  union {
    #declare Z = 0;
    #while (Z < 20)
      #declare X = 0;
      #while (X < 20)
        object {
          o_Brick
          texture
Z*(4+l_Gap)>/12
        object {
          o_Brick
Z*(4+l_Gap)>/12
          scale <1,1.001,1>
        #declare X = X + 1;
      #declare Z = Z + 1;
    texture
      pigment {p_Stripe}
#declare o_Road =
  union {
    #declare Z = 0;
    #while (Z < 10)
      #declare Z = Z + 1;
object { o_Road }
//END
What I did was duplicate each brick object (except without the texture), scale
it slightly in the y direction, and add a partially transparent texture to the
union of both sets of bricks.
This may not be what you want. But, it looks OK to me from a reasonable
distance. Since the shape of the bricks is the same (I didn't notice any random
values that might cause problems if overlooked), the striped pattern will
conform to the desired shape.
I know that you it /is/ possible to override the texture (or stack multiple
textures) within a single object. I guess this is in fact not possible for the
union of the very same objects. There's probably a good reason for this (at
least as a default behavior).
Let me know if this works out OK for you.
Date: 16 Jan 2008 15:22:09
Message: <6moso3tj40fk2t456s2djp5to9labhhtcs@4ax.com>
SharkD,
Thanks for your reply.
That's an interesting approach, but the lines would still be duplicated for each
section, which is not what I'm looking for.  Also, there may be some coinciding
surfaces issues by just scaling the
bricks in the y direction, but they may not be visible enough for concern.
A similar effect can be achieved by using layered textures for each brick, as
demonstrated below.  This eliminates the need to have a second brick object and avoids
the possible coinciding surfaces
issue.
// Replace both object statements in your code with this single statement
        object {
          o_Brick
          texture
          texture
            pigment {p_Stripe}
Date: 16 Jan 2008 17:45:00
Message: <web.478e882f26ad74ae368884fc0@news.povray.org>
Kyle <hob### [at] gatenet> wrote:
> SharkD,
ng for.  Also, there may be some coinciding surfaces issues by just scaling the
e need to have a second brick object and avoids the possible coinciding surfaces
> issue.
You're right. Applying the texture to the brick is the proper way of doing it.
Try this:
//BEGIN
//+w700 +h500
global_settings {
  assumed_gamma 1
  max_trace_level 15
  location <0, 100, 0> look_at 0// angle 54
  translate z*20
// basic brick
#declare p_Brick =
    gradient x
    color_map {
#declare p_Clear =
   color rgbt <1,1,1,1,>
#declare p_White =
   color rgbt <1,1,1,0,>
#declare p_Stripe_x =
    gradient x
    pigment_map {
      [0 p_Clear]
      [7/16 p_Clear]
      [7/16 p_White]
      [9/16 p_White]
      [9/16 p_Clear]
      [1 p_Clear]
    warp { turbulence 0.1 octaves 3 lambda 1.5 omega 0.3 }
#declare p_Stripe_z =
    gradient z
    pigment_map {
      [0 p_Clear]
      [3/16 p_Clear]
      [3/16 p_Stripe_x]
      [13/16 p_Stripe_x]
      [13/16 p_Clear]
      [1 p_Clear]
#declare o_Section = 0;
#declare o_Road =
  union {
    #declare S = 0;
    #while (S < 10)
    union {
      #declare Z = 0;
      #declare section_translate = z*S*20*(4+l_Gap)/12;
      #while (Z < 20)
        #declare X = 0;
        #while (X < 20)
          #declare brick_translate = <(X-10 #if(Z/2=int(Z/2)) +0.5
#end)*(8+l_Gap), 0, Z*(4+l_Gap)>/12;
          object {
            o_Brick
         pigment {p_Stripe_z}
         translate x*.5
         scale 10
         translate -brick_translate
         translate -section_translate
            translate brick_translate
          #declare X = X + 1;
        #declare Z = Z + 1;
   translate section_translate
      #declare S = S + 1;
object { o_Road }
//END
