POV-Ray : Newsgroups : povray.general : Can't make object shadowless Server Time
15 Jan 2026 23:12:09 EST (-0500)
  Can't make object shadowless (Message 1 to 3 of 3)
Subject: Can't make object shadowless
Date: 19 Mar 2004 18:36:18
Message: <hgum505v3ifs97661oof92mhtitp1qfd5g@4ax.com>
The following code produces a sphere with a hole going through the
middle, and the sphere is semi-transparent so the hole can be seen.
The problem I am having is I can't stop the shadow from occurring on
the sphere from the cylinder object.
I know I can make the lightsource shadowless, but then I don't get the
shadow from the sphere on the plane.
The no_shadow keyword does not work for an object when it is inside a
difference command.
Help is appreciated.
DeLeon
*** CODE BELOW ***
# include "colors.inc"
#declare CamLoc = < 0,2,-2.5>;
	location CamLoc
	look_at < 0, 0, 0>
light_source {CamLoc color White*1.2}
light_source {<50, 50,75> color White*1.7}
plane { <0, 1, 0>, -1
      checker color Red * 0.5, color Blue * 0.5
difference {
    sphere {<0, 0, 0>,
        1
        pigment {color Green filter .35}
    cylinder {<0, -1, 0>,
              <0, 1, 0>,
        .2
        pigment {color Green}
        no_shadow
Subject: Re: Can't make object shadowless
Date: 20 Mar 2004 05:14:49
Message: <405c1999@news.povray.org>
dt7### [at] bellsouthnet wrote:
> difference {
>     sphere {<0, 0, 0>,
>         1
>               <0, 1, 0>,
>         .2
>         no_shadow
  One solution which comes to mind is to clip the sphere with the
cylinder (with clipped_by) and then adding an shadowless open cylinder
in the same place. Something like this:
union
{ sphere
  { 0, 1
    clipped_by { cylinder { -y, y, .2 inverse } }
    pigment { rgb y filter .35 }
  cylinder
  { -y, y, .2 open no_shadow
    pigment { rgb y }
  (The problem is that the borders of the cylinder will not match with
the surface of the sphere so you'll have to shorten the cylinder so that
they match.)
Date: 20 Mar 2004 06:36:22
Message: <AcyILBAVsCXAFwid@econym.demon.co.uk>
>difference command.
Here's one possibility
Step 1: apply no_shadow to the whole difference
difference {
    sphere {<0, 0, 0>,
        1
              <0, 1, 0>,
        .2
       no_shadow
Step 2: add a no_image sphere in the same place to cast a shadow that
looks just like what the sphere would have cast.
sphere {<0,0,0> 1
 no_image
Optional Final tweak: Cut a hole in the invisible sphere. This changes
the amount of light that hits the inside of the hole.
sphere {<0,0,0> 1
 clipped_by {cylinder {<0,-2,0><0,1,0>,.2 inverse}}
 no_image
Mike Williams
Gentleman of Leisure
