POV-Ray : Newsgroups : povray.general : compiled functios Server Time
30 Dec 2025 03:34:13 EST (-0500)
  compiled functios (Message 1 to 10 of 11)
Subject: compiled functios
Date: 6 Feb 2002 07:20:05
Message: <g9726u02voq27v8umjek99f3h0i480rbdt@4ax.com>
I wonder - is there any other non-exotic language which compile functions
"on-line" and allow execute this compiled function just in next line of script ?
Are "our" 3.5 functions{} some novelty in languages?
ABX
Subject: Re: compiled functios
Date: 6 Feb 2002 08:27:48
Message: <3c612f54@news.povray.org>
: I wonder - is there any other non-exotic language which compile functions
: "on-line" and allow execute this compiled function just in next line of script ?
: Are "our" 3.5 functions{} some novelty in languages?
  Nope, it's nothing new. Many scripting languages use this technique for
speed. The most notorious one is Perl, which runs its scripts by first
byte-compiling them on the fly to memory and then interpreting this bytecode.
This is why Perl is so fast (as an interpreted scripting language).
Date: 6 Feb 2002 08:52:58
Message: <r1c26ug57jcp5tlbe81m1rld45c2slmh45@4ax.com>
I don't know Perl but what I understad from your answer Perl compiles whole
script. What I asked is: is there any other language which compile one
parametrized expresion to use in next expression within the same interpreted
script?
ABX
Date: 6 Feb 2002 09:11:51
Message: <3c6139a6@news.povray.org>
: What I asked is: is there any other language which compile one
: parametrized expresion to use in next expression within the same interpreted
: script?
  Uh? What's the difference?
  That's basically what Perl does.
Date: 6 Feb 2002 09:27:35
Message: <slrna62fap.5ps.ron.parker@fwi.com>
>: script?
Nope, Perl compiles the whole script, then runs it.  He's asking whether there
are any other languages that are hybrid between byte-compiled and interpreted.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 6 Feb 2002 10:20:16
Message: <3c6149b0@news.povray.org>
> there are any other languages that are hybrid between byte-compiled and
> interpreted.
  Yes, I think Clipper used such pseudointerpreted things...  I used it for
years, but I don't remember anything right now. Memory is so nice... :)
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 6 Feb 2002 10:48:00
Message: <e0j26u4vfbjptnbrid9r60q7aob4l093n7@4ax.com>
Yes, that's it.
Let's imagine such example:
I can start infinite loop with 3.5 which all the time checks for existence of
two specified files. First contains vertices of poly, second - list of points.
When files appear then my loop starts macro, read first file and makes function
to test if given point is inside this polygon. Then it starts loop along second
file and checks all points with speed of compiled program. Somehow it outputs
result, unlocks variables, clear files and continue infinite loop.
Of course it's only imagination - in reality it could be wasting of CPU for this
infinite loop. What I wanted to show - all was done with only one script but
with speed of compiled program without anything like "eval" or included
temporary files.
ABX
Date: 6 Feb 2002 15:57:55
Message: <3c6198d1@news.povray.org>
: Nope, Perl compiles the whole script, then runs it.  He's asking whether there
: are any other languages that are hybrid between byte-compiled and interpreted.
  Ok. There might not be many popular languages which do this kind of thing
(although I wouldn't be surprised if there were less-known languages which
do something like this).
  In fact, I have myself done a library which can be used for this kind of
thing: http://iki.fi/warp/FunctionParser/
Date: 6 Feb 2002 23:09:42
Message: <3C61FE5A.5A995018@sw-tech.com>
Forth, but I don't think it's hybridized in the way that you want.
Deaken
Date: 8 Feb 2002 15:41:05
Message: <3c64364c.268368740@news.povray.org>
The first graphics software I saw using compiled functions was
FractInt (in the formula interpreter), and that was at least 5 years
ago.
/Erkki
