POV-Ray : Newsgroups : povray.general : cosmetic issue around "Camera is inside ...." Server Time
26 Nov 2025 22:22:12 EST (-0500)
  cosmetic issue around "Camera is inside ...." (Message 1 to 4 of 4)
Subject: cosmetic issue around "Camera is inside ...."
Date: 30 Jul 2002 12:05:15
Message: <g0edkugdtlps0i8kuurqja67bifiolr0q2@4ax.com>
I wonder why warning with "Camera is inside a non-hollow object...." is
outputed during rendering and not before. When I start rendering with
+GAfile.txt option, it contains at begining:
Creating bounding slabs.
Scene contains 3 frame level objects; 0 infinite.
Creating light buffers
Displaying...
Rendering...
  -:--:-- Rendering line    0 of 3600 supersampled 0 times.
  -:--:-- Rendering line    1 of 3600Warning: Camera is inside a non-hollow
object. Fog and participating media
may not work as expected.
 supersampled 1927 times.
  0:00:03 Rendering line    2 of 3600 supersampled 1872 times.
ABX
Subject: Re: cosmetic issue around "Camera is inside ...."
Date: 30 Jul 2002 18:14:03
Message: <web.3d470f95a0fd0c26264908380@news.povray.org>
How do you test if it's inside?
You have to trace a ray, that's why it shows up on the first line.
I'm not that familiar with the code, so if it's wrong don't flame me.
=RAY=
Date: 31 Jul 2002 04:25:50
Message: <3d479f0e@news.povray.org>
Maybe it's done this way, but I'm sure it isn't necessary. You can test if
a point is inside an object by using (e.g.) inside(O,V). If you imagine the
whole scene as an union, you can test this way whether the camera is inside
any object.
light_source{0#macro L(K,H,W)sphere{H.5}sphere{K.5}sphere{W.5}cylinder{
H,K.5}cylinder{H,W.5}#end 3}union{L(0v*-2<2,-2>)L(y*-3z-v*5z*3-y)L(-y*3
0u*3)L(y*-3v*-5-z,z*-3-y)rotate-v*clock pigment{rgb.5}translate<0,2,9>}
// +KFF200 +KF720 +W120 +H90 -F -A -GA -P
Date: 31 Jul 2002 09:17:48
Message: <3d47e37c@news.povray.org>
  No, you don't.
