POV-Ray : Newsgroups : povray.general : How to output 8-bit Grayscale Bitmap files? Server Time
20 Apr 2026 05:53:54 EDT (-0400)
  How to output 8-bit Grayscale Bitmap files? (Message 1 to 3 of 3)
Subject: How to output 8-bit Grayscale Bitmap files?
Date: 21 Dec 2003 04:08:26
Message: <ffoauv86akm6q49j6oppo9s5n2ntov21sm@4ax.com>
I'm using POV 3.5 for Windows, and I'm having a bit of trouble finding
a combination of switches and options that will render a scene as an
8-bit grayscale, in Windows bitmap format.
I can get a Windows bitmap that is rendered in only shades of gray,
but when I check this in an image editor, I find it was actually
stored in a 24-bit RGB format.
How do I get a single channel, 8-bit, grayscale, windows bitmap?
thanks,
McLilith
Subject: Re: How to output 8-bit Grayscale Bitmap files?
Date: 21 Dec 2003 06:13:38
Message: <Xns94587C6177087seed7@netplex.aussie.org>
It will not work for BMP's as you cannot set another colourdepth for
these, but if PNG's are ok, the put +FN8 on the commandline and 'hf_gray_
16' within the global_settings statement.
... or use the post_frame / post_scene command in your ini-file to start a
conversion utility.
Ingo
Date: 22 Dec 2003 03:55:43
Message: <c3cduvk2t26pcbej1igg7rstifhpp4ddvq@4ax.com>
>these...
Okay, I'll just create grayscale PNG files, and convert them after the
render with a post_frame / post_scene command. I just happen to have a
command-line PNG2BMP utility. I only hope that IT works with grayscale
images.   :)
thanks,
Glen
