POV-Ray : Newsgroups : povray.general : Random colors or textures on mesh triangles? Server Time
22 Apr 2026 22:09:19 EDT (-0400)
  Random colors or textures on mesh triangles? (Message 1 to 3 of 3)
Subject: Random colors or textures on mesh triangles?
Date: 5 Jul 2002 13:39:47
Message: <eNglPZHxUJU++7jXESWFJ=KRzx6A@4ax.com>
Using POV 3.5, is it possible to randomly color each triangle in a
mesh? I thought I had done this in earlier versions of POV, but can't
seem to get it to work now.
Ideally, I'd want each triangle's RGB color values to be selected from
the full RGB gamut, and not to be selected from a list of sample
colors or textures.
Can it be done? What syntax do I use?
thanks,
Glen
Later,
Glen
7no### [at] ezwvcom     (Remove the numeral "7")
Subject: Re: Random colors or textures on mesh triangles?
Date: 5 Jul 2002 13:58:07
Message: <sbnbiu8ntemmbfeqc5lgblrhk7ruf03cld@4ax.com>
Take a look in documentation for all keywords started from 'triangle'. The
second one should be 'triangle texture interpolation'. Is it what you are
looking for ?
ABX
Date: 5 Jul 2002 18:23:22
Message: <chrishuff-7830FA.17204805072002@netplex.aussie.org>
In article <eNglPZHxUJU++7jXESWFJ=KRzx6A@4ax.com>,
> colors or textures.
Making each triangle a random solid color? Just generate a unique
texture for each triangle. The only restriction is that you have to
declare the texture before you can use it in the mesh triangle.
Something like this should work:
#declare RS = seed(328947);
#macro RColorTri(ptA, ptB, ptC)
    #local triTex =
    texture {pigment {color rgb < rand(RS), rand(RS), rand(RS)>}}
    triangle {ptA, ptB, ptC texture {triTex}}
Actually, this should probably work:
#macro RColorTri()
    #local triTex =
    triTex
mesh {
    triangle {ptA, ptB, ptC texture {RColorTri()}}
This will increase memory usage quite a bit though...if you used a list
of textures instead of having a separate texture for every triangle, it
would cut this down. You might also use the color macros in colors.inc
to make only the hue random, making all the random colors of the same
saturation and brightness.
