![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I recently made a macro to do almost-perfctly-centered text. Anyone
interested?
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> interested?
I'm interested. What is wrong with centered around bounding box? Or is it the
same? Could you provide some image to show atventage of your
"almost-perfctly-center" ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm not sure what the advantage is over 'centered bounding boxes' (to be
perfectly honest I've never heard of using such a technique to do this).
//Mahalis
news:nh0lutchh0ph8b0olp9pvohdq94tklu3pi@4ax.com...
> > interested?
the
> ABX
1}}
//ABX
1}}//POV35
Download 'text.png' (11 KB)
Preview of image 'text.png'
![text.png](/povray.general/attachment/%3C3bea873f%40news.povray.org%3E/text.png?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
See the Center_Object() macro in 'shapes.inc'
BTW, you should know that you should not post binaries in this group.
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
With MegaPOV and POV 3.5 you can find useful vector functions min_extent and
max_extent to get lower and higher corner of bounding object. With this you can
find center and size of any object. It is not perfect center but good enough in
almost all situations. You can use it as:
#declare Text=text {ttf "crystal.ttf" "Mahalis" 2 0};
#declare Min=min_extent(Text);
#declare Max=max_extent(Text);
#declare Size=Max-Min;
#declare Center=(Max+Min)/2;
object{Text translate -Center}
You can also find Center_Object in 3.5's standard include files.
So, is your solution still almost-perfect ?
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, I see 6 lines of code there, as opposed to:
ctext("MaHaLiS","C:\Windows\Fonts\ocrb.ttf",0.125,yes,texture{pigment{Blue}
finish{reflection 0.25 metallic}},interior{})
//Mahalis
news:l82lutola6vcavbh9qopoho3h7m1itbvjo@4ax.com...
and
you can
enough in
> ABX
1}}
//ABX
1}}//POV35
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oh, you want count?
So let's simplify this 6 lines, remove not necessary space and group to macro
#macro Center(O)object{O translate-(max_extent(O)+min_extent(O))/2}#end
is your macro shorten? :-)
Note it works fine with all objects.
Center(text{ttf "crystal.ttf" "Mahalis" 2 0})
Center(sphere{0,1})
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Poo. Well.. that only works in POV 3.5, whereas mine works equally well in
3.1 and 3.5.
Look, I'm really scraping the bottom of the barrel here.. :-)
//Mahalis
news:qm3lutsk4ug928itbjhpounodvn89m2u0b@4ax.com...
> Oh, you want count?
macro
> Center(sphere{0,1})
> ABX
1}}
//ABX
1}}//POV35
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Mahalis" <don### [at] fakey com> wrote in message
news:3beaa261$1@news.povray.org...
> 3.1 and 3.5.
No your not - your grasping at straws ;)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Okay, okay, I get the message. No one wants my poor little macro [sniff]
<g>
//Mahalis
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
