![](/i/fill.gif) |
In article <3d4d9316@news.povray.org>,
"Johan Feyaerts" <joh### [at] no_spam skynet be> wrote:
> I've been doing some trials with media in an attempt to model some neon
> lights. Is there a way to make the media fade out in the outer cylinder so
> that the boundary of the shining light is less sharp? I'd like to make the
> light more intense closer to the bulb and less intense far away from the
> bulb. Any suggestions?
If you are going to ask a question, you are more likely to get an answer
in one of the discussion groups, like povray.general or
povray.advanced-users. This group was the right place for the scene
file, the wrong one for the image and question. The best way would be to
post your message in a discussion group and the image in
povray.binaries.images. Followups to this message are set to
povray.general.
About your question: you could make a custom density pattern using a
function, you would need to know a bit of mathematics though and it
would get more difficult for more complex light shapes. One possibility
is to create several versions of the object with increasing radius and
combine these in a function pattern using the inside() function. This
would be easier if the object was created with a macro, so you didn't
have to duplicate it by hand for each new radius.
What you seem to be trying to simulate here is atmospheric scattering of
the light coming from the neon tube...you could place a lot of light
sources inside the tube and use scattering media, but it would probably
be too slow to be practical.
If you are willing to give up the refinements of POV 3.5, you could use
MegaPOV for its "glow" feature, which would be fast rendering at least.
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
![](/i/fill.gif) |
