POV-Ray : Newsgroups : povray.general : My little addition to wishes list for POV 4 Server Time
30 Dec 2025 12:40:38 EST (-0500)
  My little addition to wishes list for POV 4 (Message 1 to 10 of 17)
Subject: My little addition to wishes list for POV 4
Date: 20 Nov 2001 09:37:00
Message: <bcqkvtgeu3i7ef6aar3tudlalu7mi1sh0t@4ax.com>
I know there is workaround with functions, macros, pigments and other things but
I vote for:
  #declare Image=image_map{...}
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Subject: Re: My little addition to wishes list for POV 4
Date: 20 Nov 2001 09:57:41
Message: <3BFA6FB5.B14DDB08@pacbell.net>
> I vote for:
#declare Image = pigment { image_map {...} }
object { my_object pigment { Image } }
Ken Tyler
Date: 20 Nov 2001 10:07:50
Message: <16skvt0eun0q1ceger12qkah5ala066eom@4ax.com>
> > I vote for:
As I said I know about such workarounds. That's why I didn't wrote 'help needed'
however thanks for good intentions. :)
ABX
Date: 20 Nov 2001 10:13:19
Message: <3BFA7355.441880F4@pacbell.net>
> > > I vote for:
I am not so sure that this qualifies as a "workaround". It is simply
what the parser expects since the image_map is one possible component
of a pigment.
Ken Tyler
Date: 20 Nov 2001 10:37:03
Message: <3bfa789f@news.povray.org>
> It is simply what the parser expects since the image_map
> is one possible component of a pigment.
I'd like to be able to declare separately anything that appears inside {...}
brackets. I think ABX was thinking in the same lines, or perhaps partly so.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 20 Nov 2001 10:37:30
Message: <b7tkvto70fu19i9op1er57kbn12p5qnc3t@4ax.com>
> of a pigment.
I know 'color_map' 'image_map' 'pigment_map' are only names but according to
'_map' appendix IIRC only image_ and bump_ can't be declared. When you use the
same image as bump_map then it allocates space for image twice. So ideal
situation could be something like:.
#local Image=image{png "imagefile.png"}
#local P=pigment{image_map{image{P} image_modifiers}}
#local N=normal{bump_map{image{I} bump_modifiers}}
ABX
Date: 20 Nov 2001 11:07:44
Message: <3bfa7fcf@news.povray.org>
:   #declare Image=image_map{...}
  Perhaps the closest thing currently (besides making it just a pigment)
would be making it a pigment function. The advantage of this is over declaring
a pigment is that you can use the function anywhere:
#declare Image = function { pigment { image_map { ... } } }
  pigment { function { Image(x,y,z) } }
  normal { function { Image(x,y,z) } }
  interior { media { density { function { Image(x,y,z) } } } }
Date: 20 Nov 2001 11:14:01
Message: <3BFA8146.FF2C88E0@gmx.de>
> I vote for:
If there is something like that i would vote for a different solution that
includes heightfields for example, of course i could use a
function-image_map construction, but having a possibility to declare
images for both heightfields and image maps and at the same time avoiding
double storage of data would be a good idea IMO.
Date: 20 Nov 2001 11:24:59
Message: <vr0lvt43lnqm1lsmfcpj4hpg9oop03euvu@4ax.com>
On Tue, 20 Nov 2001 17:13:58 +0100, Christoph Hormann <chr### [at] gmxde>
That's what inspired me - storage of images.
ABX
Date: 20 Nov 2001 15:42:45
Message: <3bfac044@news.povray.org>
: That's what inspired me - storage of images.
  And why function { pigment { image_map { ... } } } doesn't do this?
