POV-Ray : Newsgroups : povray.general : Collision chance Server Time
4 Mar 2026 17:30:46 EST (-0500)
  Collision chance (Message 1 to 10 of 13)
Subject: Collision chance
Date: 24 Apr 2021 13:44:32
Message: <XnsAD16C8D2DAFAAseed7@news.povray.org>
Currently I'm working on a sequencer and ADSR. They require a lot of
array manipulation. The system I use, give everything a name, works quite
well. The names get long and I'd like to shorten tem. Hence te question,
what are the chance on collisions with names from other file for only
#local names. I'd like to drop the _sq bit but then I'm left with rather
general names like _out.
Code snippet:
// Setting up the data structure for the sequencer
// Enum primary index
#declare _sq_ctrl = 0;
#declare _sq_out = 1;
#declare _sq_row = 2;
#declare _sq_primary_arr = array[3]{
  "_sq_ctrl",
  "_sq_out",
  "_sq_row"
// Enum secondary indices
// ctrl
#declare _sq_bpm = 0;
#declare _sq_steps = 1;
#declare _sq_srate = 2;
#declare _sq_beat_samples = 3;
#declare _sq_pattern_samples = 4;
#declare _sq_tick = 5;
#declare _sq_ctrl_arr = array[6]{
  "_sq_bpm",
  "_sq_steps",
  "_sq_srate",
  "_sq_beat_samples",
  "_sq_pattern_samles",
  "_sq_tick"
// output
#declare _sq_clk_gate = 0;
#declare _sq_clk_pulse = 1;
#declare _sq_beat_prog = 2;
#declare _sq_pattern_prog = 3;
#declare _sq_col_curr = 4;
#declare _sq_col_gate = 5;
#declare _sq_row_output = 6;
#declare _sq_output_arr = array[7]{
  "_sq_clk_gate",
  "_sq_clk_pulse",
  "_sq_beat_prog",
  "_sq_pattern_prog",
  "_sq_col_curr",
  "_sq_col_gate",
  "_sq_row_output",
#macro SEQinit(BPM, Rows, Steps, SampleRate)
  /*: Initialise a sequencer. Rows, steps are filled with zero's
  They have to be set later with SEQSetRow
  #local SEQarr = array[3];
  #local SEQarr[_sq_ctrl] = array[6];
  #local SEQarr[_sq_ctrl][_sq_bpm] = BPM;
  #local SEQarr[_sq_ctrl][_sq_steps] = Steps;
  #local SEQarr[_sq_ctrl][_sq_srate] = SampleRate;
  #local SEQarr[_sq_ctrl][_sq_beat_samples] = BPM2Samples(
    SEQarr[_sq_ctrl][_sq_bpm], SEQarr[_sq_ctrl][_sq_srate]
  #local SEQarr[_sq_ctrl][_sq_pattern_samples] = (
    SEQarr[_sq_ctrl][_sq_beat_samples] * SEQarr[_sq_ctrl][_sq_steps]
  #local SEQarr[_sq_ctrl][_sq_tick] = 0;
  #local SEQarr[_sq_out] = array mixed[7];
  #local SEQarr[_sq_out][_sq_clk_gate] = 0;
  #local SEQarr[_sq_out][_sq_clk_pulse] = 0;
  #local SEQarr[_sq_out][_sq_beat_prog] = 0;
  #local SEQarr[_sq_out][_sq_pattern_prog] =0;
  #local SEQarr[_sq_out][_sq_col_curr] = 0;
  #local SEQarr[_sq_out][_sq_col_gate] = arrFill(Steps, 0);
  #local SEQarr[_sq_out][_sq_row_output] = arrFill(Rows, 0);
  #local SEQarr[_sq_row] = array[Rows];
  #for(i, 0, Rows - 1)
    #local SEQarr[_sq_row][i] = arrFill(Steps,0);
  SEQarr
#macro SEQsetBPM(SEQarr, BPM)
  /*The boom tschack speed*/
  #local SEQarr[_sq_ctrl][_sq_beat_samples] = BPM2Samples(SEQarr
[_sq_ctrl][_sq_bpm], SEQarr[_sq_ctrl][_sq_srate]);
  #local SEQarr[_sq_ctrl][_sq_pattern_samples] = SEQarr[_sq_ctrl]
[_sq_beat_samples] * SEQarr[_sq_ctrl][_sq_steps];
#macro SEQsetRow(SEQarr, ValArr, Row)
  /*Set values for a whole row*/
  #local SEQarr[_sq_row][Row] = ValArr;
Subject: Re: Collision chance
Date: 24 Apr 2021 14:35:00
Message: <web.60846401cab7490879819d986cde94f1@news.povray.org>
hi,
ingo <ing### [at] tagpovrayorg> wrote:
> ... I'd like to drop the _sq bit but then I'm left with rather
>   "_sq_out",
if you're prepared to only save two chars per, you could still keep your
prefix[*], eg 'sqOut' perhaps.
[*] and if there's a name clash, with prefix you can still use a tool like 'sed'
(on *nix) to make a quick search and replace.
regards, jr.
Date: 24 Apr 2021 17:15:59
Message: <XnsAD16ECAC19303seed7@news.povray.org>
in news:web.60846401cab7490879819d986cde94f1@news.povray.org jr wrote:
> 'sed'
With the windows "pov ide" changes can be made fast and all the Unix tools
run fine when using th eproper packages. It just that it all adds up, even
if it is just a few characters.
#local ADSRarr[_adsr_decay][_adsr_base] = (ADSRarr[_adsr_sustain]
[_adsr_level] - ADSRarr[_adsr_target_ratio][_adsr_dr]) * (1 - ADSRarr
[_adsr_decay][_adsr_coef]);
#local ADSRarr[_decay][_base] = (ADSRarr[_sustain][_Level] - ADSRarr
[_target_ratio][_dr]) * (1 - ADSRarr[_decay][r_coef]);
In general I have no problems with collisions, but with arrays I'm not
relley sure as I declare an array, the pass it to a macro where I change
it using #local 'in place' without 'returning' anything.
Guess I'll give it a go and see waht goes wrong, in time,
Cheers,
Ingo
Date: 24 Apr 2021 17:45:00
Message: <web.608490f6cab7490879819d986cde94f1@news.povray.org>
hi,
> > 'sed'
> ... It just that it all adds up, even
have long had a "dream" of a 2-pass scene file optimiser.  (pipe dream :-))
pass one analyse scene and strip comments, find and paste all needed snippets
from includes, in pass two replace all identifiers with generated 'ANNN'.
perfectly unreadable, but used as a last step..  anyway, interesting problem.
regards, jr.
Date: 24 Apr 2021 18:08:54
Message: <XnsAD171822FCA7seed7@news.povray.org>
OK, confession time. Many many moons I wrote a python script to parse POV-
Ray scene files and do loop enrolling and a few other manipulations. The
result ran fast! Python (1.52) not so. Gain, negative :(
The python code I use to colorise the code in HTML is a spin-off of that.
Now, dreaming. Include files compileable to libraries. If I understand it
right if POV-Ray SDL were written in NIM macros it could be possible. Or
in LISP. Then again, I happy with the simple language POV-Ray offers.
There is not much in the way of writing anything and little complexity
from the language side.
Also I'm happy with the journey POV-Ray offers. No need for real time
instant gratification/satisfaction. No bucktlists. No expectations. No GPU
madness.
Ingo
Date: 24 Apr 2021 18:15:00
Message: <web.6084981fcab7490879819d986cde94f1@news.povray.org>
hi,
(it is late and all that, but a thought just occurred)
how about "devolving" your array into a dictionary with keys for '_decay',
'_target_ratio', etc, parallel arrays, so to speak.  eg:
#local ADSRD._decay._base = (ADSRD._sustain._Level - ADSRD._target_ratio._dr) *
(1 - ADSRD._decay.r_coef);
not an option?
regards, jr.
Date: 24 Apr 2021 18:20:00
Message: <web.6084991ecab749081f9dae3025979125@news.povray.org>
So, was that you?
http://news.povray.org/povray.general/thread/%3C602067b2%241%40news.povray.org%3E/
Date: 24 Apr 2021 18:35:00
Message: <web.60849c6dcab749081f9dae3025979125@news.povray.org>
> well. The names get long and I'd like to shorten them. Hence the question,
What if you took everything that you wanted to have in a namespace and put them
into an include file.
Each include file could have a number associated with it.
Then instead of hard-coding the names and value assignments, you could use the
parse_string macro to make identifiers like _out1, _out2, etc.
Make a little macro like:
Declare (Lvalue, value)
so that the code reads mostly like usual and there's not a lot of extra code.
When you include one of these files, the first thing it does is check to see if
a global counter variable is set, and what its value is.  Then it uses the next
greater integer for its Lvalue names.
Then you could mix and match them any way you wanted, and you'd _always_ be
guaranteed to have distinct names.
Date: 25 Apr 2021 01:03:12
Message: <XnsAD1747BF066B3seed7@news.povray.org>
in news:web.6084991ecab749081f9dae3025979125@news.povray.org Bald Eagle
> So, was that you?
https://ingoogni.nl/download/povsdl2html.py
but I don't remember rendering an image with it.
At a certain moment the code was also used in the pyvon editor
Ingo
Date: 25 Apr 2021 01:04:12
Message: <XnsAD1747EB9DB42seed7@news.povray.org>
in news:web.6084981fcab7490879819d986cde94f1@news.povray.org jr wrote:
> not an option?
Oh yes, now they seem to be fixed.
Ingo
