What material would be best for a lamp, or "cloth", or curtain/drapery on
a window?
The problem is, that such material can be lighted by light comming from
behind, but using transparent or filter gives bad results because it makes
it look like glass/plastic/folium, not like "cloth".
Some random ideas are to use - strong normal like granite 2 scale .1 but no
refletion/specular, low brilliance, no_shadow, diffuse media (but this is
very slow), or tricks with adding shadowless lights to color_group of
objects that are made of such material...
http://www.raf256.com/3d/
Computer Graphics
> a window?
The most "realistic" way to handle this may be to use an open cone with
double_illuminate and radiosity so that it brightens things around it. But
that obviously has severe shortcomings: double_illuminate doesn't model the
scattering of light through cloth very well, and radiosity isn't fast.
So, a more practical approach might be to use an object with no_shadow, and
light it manually:
finish {diffuse 0 ambient 1}
Then light will pass through it and it will appear bright. If you want it to
cast a shadow on the room, you can then add another object the same shape
with no_image, and color it with whatever transparency gives the best
shadow.
- Slime
[ http://www.slimeland.com/ ]
