POV-Ray : Newsgroups : povray.general : sugestion: get_local_point Server Time
10 Aug 2025 09:36:39 EDT (-0400)
  sugestion: get_local_point (Message 1 to 5 of 5)
Subject: sugestion: get_local_point
Date: 1 Aug 2004 07:09:19
Message: <Xns95388537A4B5Draf256com@203.29.75.35>
I have a problem when I'm doing more advanced vectors math (in animation
for example) and some points I'm calculating "by hand" using vrotate etc,
other are calculated by CSG and transformations. THe problem is when I need
to convert between both methods.
Example:
union {
  union {
    object { MY_OBJECT } // object has center in <0,0,0>
    rotate x*90
    translate y*clock
    // where will be center of MY_OBJECT in here - in this context?
  rotate z*sin(clock)  translate z*clock*2
sphere { position_of_MY_OBJECT_in_this_context 1 }
and I want last sphere to point to center of MY_OBJECT, with is not easy as
it is in other transformations context and I would heve to repeat all CSG
transforamtions manualy to calcaulate that point, with is not very
comfortable.
My suggestion is to allow syntax like:
union {
  union {
    #declare A = local_point(<0,0,0>);
    rotate x*90
    translate y*clock
  #local B = get_vector(A); // point "B" will be a normal vector that will
  // not automagicly move like A do
sphere { get_vector(A) 1 }
This should be very usable i.e. for animations when movment is created by
POV-Ray CSG/macros, not by external program.
Suggested implementation - after declaring local_point, it will automaticly
have all parsed transforms applyed to it.
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: sugestion: get_local_point
Date: 1 Aug 2004 07:50:21
Message: <fb674AAZjNDBFwV7@econym.demon.co.uk>
>Example:
>union {
>  union {
>    rotate x*90
>    translate y*clock
>comfortable.
You don't have to repeat the transforms, you just have to declare them
separately from the objects that you want to transform, like this:
#declare MOVEMENT = transform {
    rotate x*90
    translate y*clock
    rotate z*sin(clock)
    translate z*clock*2
union {
  union {
    object { MY_OBJECT }        // The main object moved
    transform {MOVEMENT}
sphere {0,1 transform {MOVEMENT}} // A sphere moved the same way
Mike Williams
Gentleman of Leisure
Date: 1 Aug 2004 08:08:24
Message: <Xns95388F3BD807raf256com@203.29.75.35>
nos### [at] econymdemoncouk news:fb6### [at] econymdemoncouk
> union {
>   union {
But what if:
union {
  union {
    difference {
      union {
        transforms
      transforms
    transforms
  transforms
But I need a wector - so that I can do mathematic calculations on it (i.e.
interpolate it, write it to file, etcP
Computer Graphics
Date: 1 Aug 2004 14:44:25
Message: <410d3a09@news.povray.org>
> But what if:
> union {
>   union {
>     difference {
>       union {
>         transforms
>       transforms
>     transforms
>   transforms
You may have to declare all of the transformations separately. If you want,
you can keep them all in place like this:
union {
  union {
    difference {
      union {
        #declare trans1 = transform{...}
        transform{trans1}
      #declare trans2 = transform{...}
      transform{trans2}
    #declare trans3 = transform{...}
    transform{trans3}
  #declare trans4 = transform{...}
  transform{trans4}
#declare MyVector = vtransform(MyVector, trans1); // (repeat for other
transformations)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 3 Aug 2004 07:55:02
Message: <Xns953A8E0FB2B96raf256com@203.29.75.35>
fak### [at] emailaddress news:410d3a09@news.povray.org
> transformations)
Thanks, that almost perfect solution :)
Computer Graphics
