POV-Ray : Newsgroups : povray.general : "Loop-the-loop" Server Time
2 Feb 2026 06:18:59 EST (-0500)
  "Loop-the-loop" (Message 1 to 10 of 12)
Subject: "Loop-the-loop"
Date: 2 Oct 2003 13:53:53
Message: <Xns94088D51573EDNone@204.213.191.226>
Anyone know the best (i.e. fastest rendering) way to make a seamless "loop-
the-loop" track?
Subject: Re: "Loop-the-loop"
Date: 2 Oct 2003 14:15:37
Message: <3F7C6B47.A91B0772@hotmail.com>
> "loop-the-loop" track?
Render one frame.  That loops fairly smoothly.
John
Date: 2 Oct 2003 14:18:04
Message: <muqonv0jdm9v73g2t5gpp02n7auk4sq9mn@4ax.com>
>the-loop" track?
A bit more detail would help:-}
Regards
Date: 2 Oct 2003 17:16:25
Message: <3f7c95a9$1@news.povray.org>
"None" <Non### [at] onca> wrote in message
"loop-
> the-loop" track?
If you just mean repeating a series of images, then I would assume that you
would be better off looping them in an external application, rather than
waste rendering time producing identical bitmaps.
Beyond that, what John and Steve said.
Date: 2 Oct 2003 18:31:51
Message: <3f7ca757$1@news.povray.org>
I'm pretty sure this person meant a loop-the-loop as in
a track that goes in a loop.  i.e.  flips over.
Like the old electronic cars we had as kids?  on the
race-track?  with the triggers that would speed it up.
It would get to a point where it would go up...up...up
and around in a circle, upside down at one point?
some people call that a loop-the-loop, or loop-de-loop.
i.e.  from the side:   ___.O.____
"Tom Melly" <fam### [at] tomandlucouk> wrote in message
news:3f7c95a9$1@news.povray.org...
> news:Xns### [at] 204213191226...
> "loop-
> > the-loop" track?
you
Date: 2 Oct 2003 18:38:53
Message: <3f7ca8fd$1@news.povray.org>
If I'm right, you want to make a race track type loop?  up up up and around?
if so, a simple bezier patch might work.  If you use Moray, it has a
totorial
on how to make bezier patches...and in the tutorial, they show you how to
twist one into a twisted ribbon type shape.  If the array was big enough
length
wise, and you played with it enough, I'm pretty sure you could get a loop,
instead
of just a twisting ribbon.
might want to download the software (if you don't already have it), and
check it out.
http://www.stmuc.com/moray/
"loop-
> the-loop" track?
Date: 2 Oct 2003 19:09:49
Message: <Xns9408C2E0E6452None@204.213.191.226>
John VanSickle <evi### [at] hotmailcom> wrote in
news:3F7C6B47.A91B0772@hotmail.com:
Thanks John, I'm sorry I didn't explain what "loop-the-loop" track is.
sOda figured me out, I meant a track loop, like in a roller coaster loop or
actually more like the old "Hot Wheels" miniature car plastic track loops.
Date: 2 Oct 2003 19:10:28
Message: <Xns9408C2FD13A0None@204.213.191.226>
Stephen McAvoy <McA### [at] aolcom> wrote in
news:muqonv0jdm9v73g2t5gpp02n7auk4sq9mn@4ax.com:
Good point, sOda figured me out though.
Date: 2 Oct 2003 19:13:41
Message: <Xns9408C388D20E7None@204.213.191.226>
"-s0da-" <ske### [at] msncom> wrote in news:3f7ca757$1@news.povray.org:
Yes, exactly!  Also like they used to have with "Hot Wheels" miniature car,
a plastic track loop.  You let go of the car from the top of the track, it
goes down and "loops the loop" without falling and continues down the
track.
Date: 2 Oct 2003 19:21:43
Message: <Xns9408C4E5AFDEDNone@204.213.191.226>
news:3f7ca8fd$1@news.povray.org:
> around?
Yup, a race track loop, exactly.
> totorial
> to twist one into a twisted ribbon type shape.  If the array was big
> enough length
> loop, instead
> and check it out.
Ok, thanks, I don't have Moray.  I'll check it out, but I think it's
shareware.  I'll see if I can make a bezier patch mathematically first.
