POV-Ray : Newsgroups : povray.general : Re: Radiosity artifacts Server Time
3 Mar 2026 02:22:42 EST (-0500)
  Re: Radiosity artifacts (Message 1 to 10 of 20)
Subject: Re: Radiosity artifacts
Date: 10 Jul 2003 13:49:22
Message: <Xns93B4C99106963raf256com@204.213.191.226>
mon### [at] stinet news:3f0d9ebb@news.povray.org
I would try to change some settings:
> Brightness:8
brightness 1
> Count:1600
if YOu want... but IMHO 300 would be enought
> Distance max:1
isn't this setting deprected in pov 3.5 ?
> Error Bound:  .001
IMHO .10 would realy be enought
> Gray threshold: .5
1.0
> Low error Factor:  .001
.60
> Min Reuse:  .004
or even little smaller
> Nearest count:  20
> Recursion limit:  1
3..5 or more
Date: 10 Jul 2003 14:10:25
Message: <3f0dac11@news.povray.org>
Just one question.  When I raise the recursion limit, the redering time
increases ALOT.  Is this normal?  When I say alot I mean like 15 to 20 times
more.  Thanks for the settings also.  I am trying them right now.
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
> Hi,
> > Brightness:8
> brightness 1
> > Count:1600
> > Distance max:1
> > Error Bound:  .001
> > Gray threshold: .5
> 1.0
> .60
> > Min Reuse:  .004
> > Nearest count:  20
> > Recursion limit:  1
> 3..5 or more
> #macro
g(U,V)(.4*abs(sin(9*sqrt(pow(x-U,2)+pow(y-V,2))))*pow(1-min(1,(sqrt(
> pow(x-U,2)+pow(y-V,2))*.3)),2)+.9)#end#macro p(c)#if(c>1)#local
l=mod(c,100
> );g(2*div(l,10)-8,2*mod(l,10)-8)*p(div(c,100))#else 1#end#end
light_source{
> y 2}sphere{z*20
9pigment{function{p(26252423)*p(36455644)*p(66656463)}}}//M
Date: 10 Jul 2003 14:16:15
Message: <s4brgvsi4ggb2d4128o3ljodpu2bel60af@4ax.com>
There is no linear dependency between recursion limit and number of traced rays.
Read interesting tutorial about radiosity in manual ?
http://www.google.com/search?q=radiosity+tutorial+POV%2DRay
ABX
Date: 10 Jul 2003 14:19:33
Message: <3f0dae35@news.povray.org>
> > Gray threshold: .5
> 1.0
I think this should be 0, not 1.0. A setting of 1.0 allows no color bleeding.
Andy Cocker
Date: 10 Jul 2003 14:55:34
Message: <3f0db6a6@news.povray.org>
In article <3f0d9ebb@news.povray.org> , "ran102" <mon### [at] stinet> wrote:
>  Here is a picture of the scene.
Please do not post binary attachments to non-binary groups.  Please read the
messages, in particular "Welcome To The POV-Ray News Groups" in the
povray.announce.frequently-asked-questions group for details.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 10 Jul 2003 16:08:46
Message: <Xns93B4E13312D77raf256com@204.213.191.226>
mon### [at] stinet news:3f0dac11@news.povray.org
Yes.
I suggest to use in radiosity adc_bailout instead of recursion limit
a) for pre-tests
recursion_limit 3 adc_bailout 1/64
b) normal
recursion_limit 5 adc_bailout 1/128
c) perfect
recursion_limit 10 adc_bailout 1/256
Date: 10 Jul 2003 16:49:31
Message: <3f0dd15b@news.povray.org>
Xns### [at] 204213191226...
> > Recursion limit:  1
> 3..5 or more
This is definitely overkill. For practical purposes, recusion is not a
measure of quality. Most scenes look good enough with recursion 1, many can
benefit from 2 (if one can afford it) and some particular settings may
deserve 3. Higher values usually serve no purpose, apart slowing down
rendering and making the scene looking washed-out.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 10 Jul 2003 17:32:51
Message: <3f0ddb83@news.povray.org>
If I'm not mistaken (and I wish I were), adc_bailout in radiosity is bugged
and simply doesn't work (adc_bailout in reflection works fine).
Until this is fixed, putting adc_bailout 1/2000, adc_bailout 1/256 or
adc_bailout 200 give the same result. Just test it :(
G.
- Posters
Date: 10 Jul 2003 18:00:01
Message: <web.3f0de0ad78b75a86bd7f22250@news.povray.org>
That tutorial is heroic - I've found it extremely useful.
Date: 10 Jul 2003 19:12:35
Message: <3f0df2e3@news.povray.org>
  Wasn't it so that in reflection/refraction it didn't work? (Could be
both, though.)
