POV-Ray : Newsgroups : povray.general : #declare Server Time
12 Jan 2026 09:22:11 EST (-0500)
  #declare (Message 1 to 10 of 25)
Subject: #declare
Date: 18 Oct 2002 07:42:48
Message: <Xns92AB8B3B44ABDraf256com@204.213.191.226>
Hello,
#declare aaa = ... ;
is probably most common exprssion in POV while using it as srcipt language,
why the idea introduced in MegaPov ( to use $aaa=...; ) was droped / not
included into officila Pov 3.5 ?
Subject: Re: #declare
Date: 18 Oct 2002 08:05:11
Message: <3daff8f7@news.povray.org>
Rafal 'Raf256' Maj <raf### [at] raf256com> wrote:
> Hello,
  I think it had some ambiguity problems in MegaPov, IIRC. Don't remember
the details...
Date: 18 Oct 2002 09:16:09
Message: <Xns92AB9C246D97Cseed7@povray.org>
in news:Xns### [at] 204213191226 Rafal 'Raf256' Maj
> language, why the idea introduced in MegaPov ( to use $aaa=...; ) was
> droped / not included into officila Pov 3.5 ?
Not an awnser to your question, but a question triggerd by it; Why is
there a #declare at all?
aaa="anythingyouwantittobe"
Ingo
p.s. I have no problem with #declare and think $... is unaesthetic.
Date: 18 Oct 2002 10:35:44
Message: <chrishuff-88DD56.10304618102002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
 "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> Hello,
1: It's ugly.
2: It's harder to read.
3: It doesn't fit in with the rest of the syntax.
4: It didn't work right. I don't know what exactly the problems were (I
never used the patch), but there were problems with it.
I don't like the current syntax either, though...take this code for
example:
#declare myCounter = 0;
#while(myCounter < 10)
    Code
    Code
    Code
    Code
    #declare myCountr = myCounter + 1;
That's an infinite loop from a simple typo, because POV doesn't know the
difference between modifying a variable and making a new one.
I made a patch that allowed this:
    #set myCountr = myCounter + 1;
#set will modify a variable, but it will give an error if it doesn't
already exist, something like "attempt to set nonexistant variable". It
is also less typing, and makes less code to modify if you decide to put
things in a macro...it works with local variables just fine, so you have
fewer #declares to turn into #locals.
This was designed to fit in with the current syntax, though. I'd rather
redesign the language and use something more like:
def myCounter = 0;
while(myCounter < 10) {
    myCounter += 1;
http://tag.povray.org/
Date: 18 Oct 2002 22:12:08
Message: <3DB0BE8C.3040102@videotron.ca>
> def myCounter = 0;
>     myCounter += 1;
Having +=, -=, etc... would certainly be nice.  Even with #declare, if
it issued and error for uninitialized variables, for example:
#while( myCounter < 10 ) {
     #declare myCountr += 1;
The parser could choke and issue an error because it doesn't know what
the initial value of "myCountr" is.
Date: 19 Oct 2002 15:52:01
Message: <3db1b7e0@news.povray.org>
Another good thing about the operator-and-assignment is that it can
save writing and make parsing faster.
  For example, consider this:
#declare Table[Index1*2+Offset1][Index2*2+Offset2] =
Table[Index1*2+Offset1][Index2*2+Offset2] + 1;
vs:
#declare Table[Index1*2+Offset1][Index2*2+Offset2] += 1;
Date: 19 Oct 2002 15:54:43
Message: <Xns92ACDEA2518DEraf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3db1b7e0@news.povray.org
$Table[$Index1*2+$Offset1][$Index2*2+$Offset2]+=1;
syntax $var_name ihas one greate advantage :
$sphere = 10;
$ior = 50;
You can use variable names that are reserved words. This is in fact VERY usefull,
in stuff like :
// from #version 3.1
#declare dispersion = 5.0;
Date: 19 Oct 2002 16:16:16
Message: <3db1bd8f$6@news.povray.org>
> $sphere = 10;
> $ior = 50;
  How do you expect to use those variable names?
Date: 19 Oct 2002 17:15:23
Message: <Xns92ACEC4D167Araf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3db1bd8f$6@news.povray.org
I.e someone will write script, with variables like say :
  a, b, c, speed, displacment, size
It will work fine, until in say POV 4.0 displacment will became a
reserved word and stop this script from working.
I like very much PHP style - where every variable name starts with '$'.
What do You think about allowing, as PHP, syntax with variant types,
say :
$x = 100;
  "foo"+$x+"bar"  will result in "foo100bar" (x is used like string)
and :
  20 + $x         will result in 120 (x is used like number)
Date: 19 Oct 2002 17:31:06
Message: <3db1cf19@news.povray.org>
Just do as the docs suggest and use at least one capital letter in your
variable names.
