POV-Ray : Newsgroups : povray.general : MIKA radiosity & pretrace question Server Time
4 Mar 2026 03:27:09 EST (-0500)
  MIKA radiosity & pretrace question (Message 1 to 4 of 4)
Subject: MIKA radiosity & pretrace question
Date: 4 Oct 2002 21:07:04
Message: <Xns929DD6EC03DD9POVMIKA@204.213.191.226>
POV Manual Quote...
6.11.11.2.13  Pretrace
To control the radiosity pre-trace gathering step, use the keywords
pretrace_start and pretrace_end within the radiosity{} block. Each of
these is followed by a decimal value between 0.0 and 1.0 which specifies
the size of the blocks in the mosaic preview as a percentage of the
image size. The defaults are 0.08 for pretrace_start and 0.04 for
pretrace_end
Yes, but does the pretrace affect the quality of radiosity or is it just
a mosaic effect for the render-window?
It's not quite clear from the above if smaller values will give better
results.
I know for sure it will generate smaller squares in the mosaic!
object {
   Grey_Matter
   photons { target Need_More_Info }
Thanks
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Subject: Re: MIKA radiosity & pretrace question
Date: 4 Oct 2002 23:57:06
Message: <3d9e6312@news.povray.org>
"Marc Champagne" <nos### [at] pleasecom> wrote in message
It is doing a sampling of areas, so yes, it is a quality factor. Pretrace
isn't the same as mosaic preview, only looks it.
Date: 5 Oct 2002 06:50:57
Message: <3d9ec411@news.povray.org>
Marc Champagne wrote:
> ...does the pretrace affect the quality of radiosity or is it just
> results.
In some cases, smaller pretrace_end values will help smooth artifacts
(slightly); in other cases, a smaller value has no appreciable effect.
Obviously, in all cases, a lower value will increase rendering time.
-Xplo
Date: 7 Oct 2002 12:27:27
Message: <3DA1B5ED.3B9BD55C@gmx.de>
> results.
In general you can say: lower pretrace_end -> higher quality and slower
render.  But how much you gain depends on the other settings.  As a rule
of thumb you can say a low error_bound also profits from low
pretrace_end.  A high error_bound combined with a low pretrace_end is just
a waste of time.
