POV-Ray : Newsgroups : povray.general : fast start render Server Time
31 Dec 2025 22:07:03 EST (-0500)
  fast start render (Message 1 to 4 of 4)
Subject: fast start render
Date: 22 Sep 2002 08:37:41
Message: <Xns929194C8D17C3raf256com@204.213.191.226>
Hello,
in bigger projects it is often a good idea to split scene into several
files. I.e. main.pov in including ufo.inc ground.inc cfg.inc
The problem is - that to render entire image while editing ufo.inc You must
switch to another window, start rendering, and switch back.
This takes only a few seconds, but since this is repeated realy often
(especialy when no additional editor is used :) it is annoying.
My suggstion - instead of :
ctrl+tab, alt+g, ctrl+tab
  press just
F5
Editor should have option to select/load active project.
What do You think ?
Ofcourse ther is a work-around for this :
in ufo.inc
  #ifndef (PRJ_LOADED_MAIN)
    #include "main.pov"
  #else
    ... entire ufo.inc scene ...
and in main.pov
  #declare PRJ_LOADED_MAIN=1;
  #include "ufo.inc"
Subject: Re: fast start render
Date: 22 Sep 2002 12:48:07
Message: <3d8df446@news.povray.org>
In emacs it's possible to put a comment at the beginning of a file,
for example a LaTeX file, that when compiling (with latex), don't compile
this file, but the one specified in the comment.
  I wonder if it would be a good idea to add this kind of support to
winpov as well... That is, some special comment at the beginning of the
pov-file would tell povray to not to render this file but the one
specified.
Date: 23 Sep 2002 05:08:15
Message: <3d8ed9ff@news.povray.org>
Hash: SHA1
I have been thinking about this problem too... Could you use +I in
the little ini window to get round this?
Andrew.
Mmm... maybe next time I should *try* it _before_ posting the msg?
news:3d8df446@news.povray.org...
> file, for example a LaTeX file, that when compiling (with latex),
> don't compile this file, but the one specified in the comment.
> to winpov as well... That is, some special comment at the beginning
> of the pov-file would tell povray to not to render this file but
> the one
> specified.
-----BEGIN PGP SIGNATURE-----
Version: PGPfreeware 7.0.3 for non-commercial use <http://www.pgp.com>
iQA/AwUBPY7Z+LEpzUF0Y1JeEQJ/+ACgngzPWZJPe7MFufQ9t+2YsSijfoQAoMI7
MiKyOoe8afzIIxODoUNhoFec
=+mrd
-----END PGP SIGNATURE-----
Date: 23 Sep 2002 09:14:55
Message: <3d8f13cf@news.povray.org>
Hash: SHA1
Just went and tried this... If you put a +I switch in the INI box
next to the resolution INI (which they kindly added in 3.5 ;-) it
seems to render the correct file - and output to the right place,
etc. Most helpful!
Andrew.
iQA/AwUBPY8SDbEpzUF0Y1JeEQJQcQCcDLX+f7nMh/ICWR52GV8ArRrtqtsAn1ag
PzDcHHbdPRPrUYm4A5beOy2K
=Ut4t
