POV-Ray : Newsgroups : povray.general : Probably simple ... Server Time
14 Jan 2026 20:15:33 EST (-0500)
  Probably simple ... (Message 1 to 5 of 5)
Subject: Probably simple ...
Date: 17 Mar 2001 06:01:20
Message: <Xns90677A8B1A12Dseed7@povray.org>
.. but can't figure it out at the moment.
I'm looking for a macro that returns a value based on an input value
(Val) within a given input range (iMin to iMax), the ReturnVal has to
be in the range oMin, oMax.
Kind of like the "how to create random numbers in a range other than 0
to 1". But then with a arbitrary input range.
#macro RVal(iMin, iMax, Val, oMin, oMax)
    	ReturnVal
Ingo
Subject: Re: Probably simple ...
Date: 17 Mar 2001 06:19:54
Message: <3ab3485a@news.povray.org>
ingo wrote in message ...
Here you are:
        #local v  = (Val - iMin) / (iMax - iMin);
        (oMin + (oMax - oMin) * v)
The first line gives you a [0,1] value and the second "returns" the result.
E.g.
    #declare qqq = RVal(0., 1., .4, 10, 20);
which expanded becomes:
    #declare qqq = (10 + (20 - 10) * (.4 - 0) / (1 - 0));
(If I got the parenthesis right!!!)
BTW, ALWAYS put between () the return value, otherwise calls like this would
be wrong:
    RVal(....) * 10
which has to be (...) * 10 and NOT oMin + (oMax - oMin) * v *10!
Bye!!!
Alessandro Coppo
P.S: have a look at POVRay documentation, this function call/procedure call
hybrid nature is well explained in #macro help.
Date: 17 Mar 2001 06:40:43
Message: <Xns906781385621Dseed7@povray.org>
in <3ab3485a@news.povray.org> Alessandro Coppo wrote:
>Here you are:
Thanks
Ingo
Date: 17 Mar 2001 10:37:49
Message: <chrishuff-401013.10321817032001@news.povray.org>
In article <3ab3485a@news.povray.org>, "Alessandro Coppo"
<a.c### [at] iolit> wrote:
> Here you are:
>     #end
Why not simplify it to this?
    (oMin + (oMax - oMin)*((Val - iMin)/(iMax - iMin)))
BTW, here are the macros I use for the same thing:
// Range handling macros
#macro Clamp(V, Min, Max) (min(Max, max(Min, V))) #end
// clamps a number to the range [Min, Max]. Values above Max return Max,
below Min return Min.
#macro Range(V, Rmn, Rmx) (V*(Rmx-Rmn) + Rmn) #end
// adjusts input values in the range [0, 1] to output values in range
[Rmn, Rmx].
#macro RRange(V, Rmn, Rmx, Min, Max) (((V-Rmn)/(Rmx-Rmn))*(Rmx-Rmn) +
Rmn) #end
// adjusts values in a specified range [Rmn, Rmx] to the specified range
[Min, Max]
Christopher James Huff
Date: 17 Mar 2001 18:50:10
Message: <3ab3f832$1@news.povray.org>
Just to make it immediately readable for...
a) ...everybody besides me and...
b) ...myself in six months time ;-)
Alessandro Coppo
a.c### [at] iolit
