![](/i/fill.gif) |
I have been using the Colefax spline macro for decades.
I have a new animation spline that gives unexpected results and I can't
figure out why. (see below)
As I walk through the spline clock, this one iteration reverses
direction 180 degrees and moves back towards the origin. Then it
reverses direction again and continues normally, but the damage is done.
By tweaking the spline points, and the loop increment, I can move the
reversed frame (currently #4 in the code below) but I can't get rid of
it. Help?
The interesting output is this. Note the one y=90 frame.
PushStool: 0.00 StoolVec=<200.00, 1.00, 200.00>
PushStool: 0.00 StoolRot=<0.00, -90.00, 0.00>
PushStool: 0.01 StoolVec=<197.84, 1.00, 200.00>
PushStool: 0.01 StoolRot=<0.00, -90.00, 0.00>
PushStool: 0.02 StoolVec=<195.68, 1.00, 200.00>
PushStool: 0.02 StoolRot=<0.00, -90.00, 0.00>
PushStool: 0.03 StoolVec=<194.36, 1.00, 200.00>
PushStool: 0.03 StoolRot=<0.00, 90.00, 0.00>
PushStool: 0.04 StoolVec=<193.47, 1.00, 200.00>
PushStool: 0.04 StoolRot=<0.00, -90.00, 0.00>
PushStool: 0.05 StoolVec=<191.31, 1.00, 200.00>
PushStool: 0.05 StoolRot=<0.00, -90.00, 0.00>
PushStool: 0.06 StoolVec=<189.15, 1.00, 200.05>
PushStool: 0.06 StoolRot=<0.00, -87.56, 0.00>
PushStool: 0.07 StoolVec=<186.99, 1.00, 200.16>
PushStool: 0.07 StoolRot=<0.00, -86.61, 0.00>
PushStool: 0.08 StoolVec=<184.83, 1.00, 200.30>
PushStool: 0.08 StoolRot=<0.00, -86.26, 0.00>
PushStool: 0.09 StoolVec=<182.68, 1.00, 200.44>
PushStool: 0.09 StoolRot=<0.00, -86.15, 0.00>
PushStool: 0.10 StoolVec=<180.52, 1.00, 200.58>
PushStool: 0.10 StoolRot=<0.00, -86.19, 0.00>
------------ >% code %< ---------------
// splinetest.pov
// with which Colefax's spline macro and I disagree
#include "splineColefax.inc"
#declare feet=12;
#declare foot=12;
#declare inches=1;
#declare inch=1;
#macro vdebug(vec)
concat("<", str(vec.x,0,2), ", ",str(vec.y,0,2), ", ", str(vec.z,0,2),
#declare arrow=
difference {
box { <-1, -1, -1> <1,1,1> }
plane { x, 0 rotate y*45 translate x*-1 }
plane { -x, 0 rotate y*-45 translate x*1 }
scale 0.2
#declare StoolPushStartVec=<200*inches, 1*inch, 200*inches>;
#declare StoolAtCookiesVec=<1*inches, 1*inch, 200*inches>;
#declare stoolToCookiesPathSpline=create_spline(
array[10]{StoolPushStartVec,
StoolPushStartVec+<-4*inches, 0, -0*inches>,
StoolPushStartVec+<-6*inches, 0, -0*inches>,
StoolPushStartVec+<-9*inches, 0, -0*inches>,
StoolPushStartVec+<-60*inches, 0, 0>,
StoolAtCookiesVec+<70*inches, 0, -25*inches>,
StoolAtCookiesVec+<40*inches, 0, 0>,
StoolAtCookiesVec+<8*inches, 0, 0>,
StoolAtCookiesVec+<4*inches, 0, 0>,
StoolAtCookiesVec}
create_default_spline + spline_loop (no) + spline_tension (0.2) +
spline_sampling(100.0)
//preview_spline (stoolToCookiesPathSpline, spline_preview_pigment
(pigment {Red}))
#local _i=0;
#while (_i<0.1)
evaluate_spline(stoolToCookiesPathSpline, spline_clock(_i))
#declare StoolVec=spline_pos;
#declare StoolRot=spline_heading+<0,0,0>;
object {
arrow
texture{ pigment{color rgb <1-_i*10/2,0.75+_i*10/4,_i*10>}}
rotate StoolRot
translate StoolVec
#debug concat("PushStool: ", str(_i,0,2), " StoolVec=", vdebug
(StoolVec), "\n")
#debug concat("PushStool: ", str(_i,0,2), " StoolRot=", vdebug
(StoolRot), "\n")
#local _i=_i+0.01;
evaluate_spline(stoolToCookiesPathSpline, spline_clock(0.1))
sphere {
spline_pos, 0.4
pigment {Blue}
location <StoolPushStartVec.x, 18*inches, StoolPushStartVec.z>+<-10
*inches, 0, 0>
look_at StoolPushStartVec+<-10*inches, 0, 0>
light_source { <StoolPushStartVec.x, 38*inches, StoolPushStartVec.z>
color rgb 1}
![](/i/fill.gif) |
