POV-Ray : Newsgroups : povray.general : Annoying problem with a rocket exhaust plume Server Time
19 Apr 2026 19:37:13 EDT (-0400)
  Annoying problem with a rocket exhaust plume (Message 1 to 3 of 3)
Subject: Annoying problem with a rocket exhaust plume
Date: 5 May 2004 19:13:37
Message: <MPG.1b03857a5484f8cf989693@news.povray.org>
I have managed to create a rocket exhaust plume that is far from perfect
but at least better than having no plume at all. Actually what I really
wanted was something resembling a bluish flame.
It doesn't look bad from a distance when silhouetted against a uniform
background, e.g. the blackness of space or a nearby planet. Problems
start when part of it is silhoutted against a black background and part
of it against a brighter background. In that case the part that is
silhoutted against the bright background appears brighter:
http://www.mmedia.is/bjj/misc/plume_test.jpg
This is unrealistic, my feeling is that this should be opposite, a
bluish flame/plume should be more visible when silhouetted against a
black background.
Two images that illustrate this problem in practice:
http://www.mmedia.is/bjj/misc/cassini_flyby_1294.jpg (OK; silhouetted
against Saturn's rings)
http://www.mmedia.is/bjj/misc/cassini_flyby_1327.jpg (not satisfactory;
silhoutted against both the rings and black space)
The code I used to render plume_test.jpg follows. I have been messing
with it without satisfactory results. I was able to make make this
particular scene look better but that solution wasn't satisfactory
because the flame could look dark against a different background,
something that's not exactly realistic. Does anyone know of a solution ?
What I think *probably* needs changes is towards the bottom (look for
"exhaust_half" and a prominent comment line).
camera  {
   location <100,0,0>
   look_at <0,10,0>
   angle 20
light_source {
  <1000,300,1500>
  color rgb <1,1,1>
#declare Thrust=0.5;
#declare nozzle_y=0.06;
#declare nzzy=1-nozzle_y;
#declare exhaust_radius=sqrt(1-nzzy*nzzy);
#declare plume_emission=0.15;
#declare plume_col=<198,247,255>/255;
#declare pl_s=0.07;
   #declare col_mul=1.0;
#local denT=density {
   spherical
   density_map {
      [0.0 rgb 0][pl_s rgb plume_col*0.7*col_mul][pl_s+0.01 rgb
plume_col*0.75*col_mul ][pl_s+0.02 rgb plume_col*0.7*col_mul]
      [0.17 rgb plume_col*0.4*col_mul][0.25 rgb plume_col*0.1*col_mul]
[0.5 rgb plume_col*0.05*col_mul][0.8 rgb plume_col*0.0]
#declare col_mul=0.9;
#local denT09=density {
   spherical
   density_map {
#declare col_mul=0.2;
#local denT02=density {
   spherical
   density_map {
#declare col_mul=0.1;
#local denT01=density {
   spherical
   density_map {
#local denT2=//denT
density  {
   gradient y
   density_map  {
      [0 denT02]
      [0.4 denT01]
      [1 rgb 0]
#local denT3=//denT
density  {
   gradient y
   density_map  {
      [0 denT02]
      [0.7 denT09]
      [0.85 denT]
      [1 denT]
#declare sphere_half=
intersection  {
   sphere {
      <0,0,0>,2
   plane {<0,-1,0>,-0.0001}
// ************************************* Probably the important stuff:
#declare exhaust_half=  // The "half-plume" farthest from the nozzle
object  {
   sphere_half
   hollow
   no_shadow
   texture { pigment { rgbt 1 } }
   interior  {
      media {
         emission plume_emission   method 3 intervals 10
         density  {
            denT2
      media  {
         absorption .2 method 3 intervals 10
         density {
            denT2
#declare exhaust_nozzle_half=  // The "half-plume" next to the nozzle
object  {
   intersection  {
      object {sphere_half}
      plane {<0,1,0>,1-nozzle_y}  // Remove what's inside the nozzle
   hollow
   no_shadow
   interior  {
      media {
         density  {
            denT3
      media  {
         density {
            denT3
#declare exhaust_plume=
merge  {
   object {exhaust_half}
   object {exhaust_nozzle_half scale <1,-1,1>}
   translate <0,nzzy,0>
   scale <1/exhaust_radius,9*Thrust/exhaust_radius,1/exhaust_radius>
object {exhaust_plume}
union  {
   box {
      <-100,-100,-100>,<-50,6.5,100>
   box {
      <-100,6.5,0>,<-50,100,100>
   pigment {White}
Subject: Re: Annoying problem with a rocket exhaust plume
Date: 6 May 2004 13:44:08
Message: <cjameshuff-466808.12431906052004@news.povray.org>
In article <MPG.1b03857a5484f8cf989693@news.povray.org>,
Rather than using separate absorbing and emitting media, use a single
media with absorbing and emitting media. In addition, your absorption
color should be 1 - emission color for the most clear results.
http://tag.povray.org/
Date: 7 May 2004 13:24:37
Message: <409bc655$1@news.povray.org>
Hash: SHA1
	MegaPov 0.7 includes a new type of emitting media that was designed
specifically for this kind of situation: look at this image for an
example:
http://jeberger.free.fr/mpov/emission3.png
	Both media were done with the following code:
~  interior {
~    media {
~      emission { 2, color rgb 1 extinction 2 }
~      method 3
~      intervals 1
~      samples 5, 5
~      density {
	spherical
	color_map {
	  [ 0.0 rgb 0.0 ]
	  [ 0.5 rgb <1.0, 0.0, 0.0> ]
	  [ 1.0 rgb <0.0, 1.0, 0.0> ]
	For a slightly more complete description, look at this web page:
http://jeberger.free.fr/mpov/mpov.html
	Unfortunately, this feature didn't make it either in POV 3.5 nor in
MegaPov 1.0 (nor AFAIK in POV 3.6) :(
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAm8ZUqIYJdJhyixIRAiK5AKCug9xsIe07iUhmJ1CuBpsE4n4HRACgpEoP
bXbiGMVoUCspDZeSItBdc/4=
=RY/x
-----END PGP SIGNATURE-----
