POV-Ray : Newsgroups : povray.general : Bug report: shapes2.inc icosahedron numerical inaccuracy Server Time
17 Aug 2025 09:19:40 EDT (-0400)
  Bug report: shapes2.inc icosahedron numerical inaccuracy (Message 1 to 4 of 4)
Subject: Bug report: shapes2.inc icosahedron numerical inaccuracy
Date: 21 Jul 2019 16:53:10
Message: <87imrvxg7g.fsf@munyer.com>
I wanted an icosahedron module for OpenSCAD, and didn't find anything
on-line that I liked, so I wrote this:
  intersection_for
      (a_z = [-180 : 72 : 179],
       a_y = [atan2 (4, 3 + sqrt (5)),
              atan2 (sqrt (10 + sqrt (20)), sqrt (5 - sqrt (20)))])
    rotate ([0, a_y, a_z])
      cube ([2, 2, sqrt (3/4) + sqrt (5/12)], true);
I thought that I could double-check my math by verifying that my
angles matched POV-Ray's angles.  They didn't quite match.  A close
view of a POV-Ray icosahedron vertex reveals that it is malformed
(see PNG in message with same subject, in povray.binaries.images).
calculated: 52.6226318593503043571428615050624824299049526181
pov-ray:    52.6625
calculated: 10.8123169635717062912849447744842228988908330822
pov-ray:    10.8125
One of POV-Ray's angles is wrong only in the last digit, but the
other angle has _three_ wrong digits.
Download 'us-ascii' (1 KB)
Subject: Re: Bug report: shapes2.inc icosahedron numerical inaccuracy
Date: 22 Jul 2019 04:25:54
Message: <5d357312$1@news.povray.org>
>   intersection_for
> pov-ray:    52.6625
> pov-ray:    10.8125
You are correct.
From wikipedia, the dihedral angle in icosahedron should be
pi-acos(sqrt(5)/3), which is 138,189685104221 degrees, it's complement
is 41,8103148957786 degrees.
The difference between pov-ray planes is 41.85 degrees, a bit too much.
The precision should probably be limited to 11 digits after the decimal
dot, similar to the dodecahedron.
But actually, just fixing the 52.6625 with 52.6225 is already enough to
solve the intersection of the 5 planes of your scene.
On the same line of precision, the tetrahedron should use something
along 19.47122063449 instead of 19.47
Date: 22 Jul 2019 05:01:18
Message: <5d357b5e$1@news.povray.org>
>   intersection_for
> pov-ray:    52.6625
> pov-ray:    10.8125
You might want to open an issue at https://github.com/POV-Ray/povray/issues
I made a fix on bugfix/angles-of-platonic-polyhedrons in
https://github.com/LeForgeron/povray.git , to be integrated in hgpovray
in the meantime.
Date: 4 Aug 2019 06:42:36
Message: <5d46b69c@news.povray.org>
I've done this using what Robert posted so we don't lost track of the
issue. See:
https://github.com/POV-Ray/povray/issues/378
Bill P.
