POV-Ray : Newsgroups : povray.general : Bug report: a different coincident-surfaces problem Server Time
24 Feb 2026 20:09:53 EST (-0500)
  Bug report: a different coincident-surfaces problem (Message 1 to 10 of 10)
Subject: Bug report: a different coincident-surfaces problem
Date: 29 Oct 2018 23:58:50
Message: <878t2gjdae.fsf@munyer.com>
The documentation explains the rendering problem that happens when one
of the surfaces of the minuend in a difference operation is coincident
with one of the surfaces of the subtrahend.
I've been encountering a similar-looking rendering problem even when
there is no such coincidence.  In the scene attached below, I expected
the center of the image to be a green solid surface, not a speckled
"window" into the object's interior.
Question 1:  Is this a bug?
Question 2:  If this is not a bug but a problem in the scene file...
Suppose that Bar and Baz were written by different authors; which one of
them is responsible?  Was the author of Bar supposed to avoid coincident
surfaces, even though he was just unioning some untextured solid objects?
Or conversely, was the author of Baz supposed to perform an audit of the
structural details of the objects that he was differencing, just in case
one of them might have its own subcomponents that have coincidences?
I'm using 3.7, and I get the same result on Linux or Windows.
(See PNG in message with same subject, in povray.binaries.images.)
Download 'us-ascii' (1 KB)
Subject: Re: Bug report: a different coincident-surfaces problem
Date: 30 Oct 2018 03:43:41
Message: <5bd80bad$1@news.povray.org>
No. It is not imho.
Bar is the offensive element with a coincident surface at z=0.
Obviously, Baz is unable to difference that coincident surface from Foo,
leaving a /hole/ (/not/ a difference surface you may have noticed). My
experience has always been to avoid coincident surfaces wherever
possible, especially in complex situations. I leave the technical
background to my betters. ;-)
Date: 30 Oct 2018 05:56:06
Message: <5bd82ab6@news.povray.org>
Am 30.10.2018 um 04:58 schrieb Robert Munyer:
No; it's a known issue that is fundamental to the way POV-Ray does
constructive solid geometry.
That's really a legal question, and therefore outside the scope of these
newsgroups; you better consult a lawyer about this. All I as a layman
can say is that as far as I am aware, there is nothing intentionally
inherent in POV-Ray or its terms of use that would imply one or the other.
Date: 30 Oct 2018 06:12:56
Message: <5bd82ea8$1@news.povray.org>
LOL!
I had not even considered the /legal/ aspect of the question. I would
consider Bar to be malignant and purposely inducing Baz into problems,
while Baz has been too stupid or just too lazy to control the received code.
I want to see both in court your honour!
Date: 30 Oct 2018 10:32:03
Message: <5bd86b63$1@news.povray.org>
Coincident surfaces problems can happen whenever you have two or more
surfaces that are at the same location.
It can come from two objects that touch each other.
It can show up in unions and merges.
It show more often in differences and intersections because, in the
other cases, the affected surfaces are hidden unless you have at least
one transparent object.
Solution : Always make sure that you don't have surfaces that just
touch. If it happen, move one of the surfaces by a tiny amount.
This will solve your problem :
#declare Bar =
   union {
     // No more surface coincidences _within_ this union.
     box { <-.75, -.75, -2>, <.25, .25, 0.000001> }
     box { <-.25, -.25, -2>, <.75, .75, 0> }
     pigment { Green }
as well as this :
#declare Bar =
   union {
     box { <-.75, -.75, -2>, <.25, .25, -0.000001> }
     pigment { Green }
Date: 30 Oct 2018 18:36:01
Message: <5bd8dcd1$1@news.povray.org>
I encounter the same problem often, with my river paddle-wheel steamboat
and other projects. Wished this could be solved somehow by the developers.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 3 Nov 2018 09:11:41
Message: <87sh0igv9x.fsf@munyer.com>
Thank you, that's very helpful advice.
I'm trying to see if any other CSG-related programs have this problem.
I tried the three other CSG programs that happen to be installed on my
system.  I asked people at the local hackerspace who have other CSG
programs.  None of the other programs seem to have this problem.
Neither I nor any of the others had BRL-CAD, so when I have some time
I will download and try it.  It will be interesting to use a ray tracer
that's even older than POV-Ray!
To be clear...  There are two coincident-surfaces problems that affect
nearly all CSG programs, but this thread is about a different problem.
If two coincident surfaces have opposite orientation (i.e. one of
them is trying to show a surface whose interior side faces the camera,
and the other one is trying to show a surface whose exterior side faces
the camera) most CSG programs will render unintended geometry:
  difference {
    box { -1, 1 pigment { Red } }
    cylinder { -z, z, 0.5 pigment { Green } }
If two coincident surfaces have the same orientation but different
texture, it's impossible to know what the author intended:
  union {
    box { -1, 1 pigment { Yellow } translate y }
This thread is about a different case, in which the coincident surfaces
have the same orientation and the same texture.
> #declare Bar =
>    union {
>      pigment { Green }
Or you can refactor Bar so that it doesn't use CSG internally:
#declare Bar =
  prism {
    -8, 0, 8,
    <-1, -1>, <-1, -3>, < 3, -3>, < 3,  1>,
    < 1,  1>, < 1,  3>, <-3,  3>, <-3, -1>
    scale .25
    rotate 90 * x
    pigment { Green }
Date: 3 Nov 2018 09:54:35
Message: <5bdda89b$1@news.povray.org>
Am 03.11.2018 um 14:12 schrieb Robert Munyer:
That's probably because CSG-capable programs usually come from the CAD
modelling world, not the 3D rendering world.
POV-Ray has a bit of a handicap in that it isn't totally committed to
solid geometry, and instead supports a random mix of patch and solid
primitives.
As a consequence, it can't just use the "direction" of the surface to
determine where the volume begins or where it ends; instead, it uses a
separately defined notion of "insideness" of a given point.
So the case you describe does pretty much fall into POV-Ray's equivalent
of this one:
Because POV-Ray doesn't distinguish surface orientation in its
implementation of CSG.
I have toyed with some ideas of how to change that and do make use of
surface orientation to address the issue at least for certain standard
cases, but it would require some major changes, and my supply of
king-size Round Tuits(TM) is running low, as always.
Date: 5 Nov 2018 07:55:52
Message: <87h8gvvg1z.fsf@munyer.com>
Thank you for posting that explanation.
Here's something that you could do with a much smaller tuit:
Put a paraphrase of the words that you wrote here (or the words that
Alain wrote here) in the documentation, wherever the current wording
obscures or contradicts what you wrote here.
For example, these words in the documentation:
    In general we have to make the subtracted object a little bit
    larger in a CSG difference. We just have to look for coincident
    surfaces and increase the subtracted object appropriately to get
    rid of those surfaces.
are misleading; their suggested remedy of "increasing the subtracted
object" wouldn't help at all, in the situation being discussed here.
P.S.  I downloaded BRL-CAD, and learned just enough of it to model the
CSG shape from the top of this thread, and ray-trace it, and export it
as STL.  I'll attach a BRL-CAD geometry database (in human-readable .asc
form) below, in case anyone here wants to experiment with it.  baz.c is
the geometric shape, and baz.r is a red plastic object with that shape.
Using the database attached below:
$ PATH=/usr/brlcad/bin:$PATH
$ # deserialize the database
$ asc2g pov-csg-problem.asc p-c-p.g
$ # ray-trace the object
$ rt -a 0 -e 5.71 -o baz.png -p 30 -E 5.9 p-c-p.g baz.r
 [ output elided ]
$ # export the CSG shape as STL
$ g-stl -o baz.stl p-c-p.g baz.c
 {foo.s} - {bar1.s}
 {(foo.s - bar1.s)} - {bar2.s}
44 triangles written
Date: 12 Nov 2018 23:12:46
Message: <5bea4f3e$1@news.povray.org>
You should see the machinations I went through to avoid coincident
surfaces in RoundEdge in the Object Collection.  Also in the Object
Collection, the GemCuts user manual has a warning that setting objects
(in contrast to gem objects) are not intended for use with transparent
textures.  The reason is that I made no attempt to eliminate internal
surfaces, but with that comes a high likelihood of hidden coincident
surfaces.  Now you have me wondering if I should include a warning not
to difference that Tiffany solitaire setting from... uh, a clay
impression?  A Styrofoam box?
Object Collection submissions are under the LGPL license, and my other
independent submissions are under the GPL.  I've also submitted
modifications and supplements to POV-Ray distribution scene files, which
are covered by Creative Commons.  All these licenses have explicit
warranty disclaimers.  So, the user's problem, not mine.  :p
