POV-Ray : Newsgroups : povray.general : Re: modelling piece of paper Server Time
29 Mar 2026 21:58:30 EDT (-0400)
  Re: modelling piece of paper (Message 1 to 2 of 2)
Subject: Re: modelling piece of paper
Date: 22 Apr 1998 14:34:31
Message: <6hld7n$co4$1@oz.aussie.org>
Actually, I am doing just that. The EASIEST way to do it, so far as I
have found, is a plane -> box intersection, making the piece with writing
flat, and the text image_map'ed onto it. If you want the edges to curl up
or down, then simply create a bezier patch and attqache it to the margin(s)
of the flat parchment. But then, that's just how I did it. There may be a
better way. =) There's ALWAYS a better way to do something in POV-Ray.
Date: 1 May 1998 01:05:45
Message: <35495829.C8D2F378@ltu.edu>
If you're looking for U/V mapping (where the image follows the bezier patch as
it's stretched), go to
http://www.public.usit.net/rsuzuki/e/povray/iso/index.html
This unofficial version of POV has a limited ability to do U/V mapping of
bezier patches.  I know about it 'cause I programmed it... I also know that
it's a bit
buggy and quite limited, but it does work.
-Nathan
